Speedo Cluster
GazDoran
Here's a pic of my speedo cluster....
I want to get some custom dials i.e. from Moman, but I couldn't help but notice that I have never seen anyone else with the range set out like mine, or the needles in such a low position (0 would normally be around where 40 is on mine and 300 roughly where 280 is). I wanted to get 220mph gauges, but as you can see from mine, given the way the range is set out, it wouldn't work/fit.
Guessing I will have to scan the gauges and get them custom made to match mine with a 180mph range? And i'm also guessing that the needles can't simply be moved to match the existing facelift template, with my gauge somehow re-calibrated so it functions/reads correctly?
Hope that's clear - Any advice appreciated.
