mrboomberang Posted November 17, 2015 Share Posted November 17, 2015 Getting a random beeping noise when driving home from work last night not contious a couple of beeps then stops then starts again it's not the reversing bleeper/ vvti tiptronic Quote Link to comment Share on other sites More sharing options...
cered Posted November 17, 2015 Share Posted November 17, 2015 Aftermarket alarm? Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted November 17, 2015 Author Share Posted November 17, 2015 Aftermarket alarm? Yes hornet alarm I think it might be this Quote Link to comment Share on other sites More sharing options...
cered Posted November 17, 2015 Share Posted November 17, 2015 Probably the weather affecting connections under the bonnet. Clean the connections, check fuses etc. Disconnecting the battery for 30mins and reconnecting might reset the system. I did this recently while fiddling with the airbag and it restored the alarm's 'beeper' function when you lock/unlock the doors. Quite handy Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted November 17, 2015 Author Share Posted November 17, 2015 Probably the weather affecting connections under the bonnet. Clean the connections, check fuses etc. Disconnecting the battery for 30mins and reconnecting might reset the system. I did this recently while fiddling with the airbag and it restored the alarm's 'beeper' function when you lock/unlock the doors. Quite handy Cheers I will give that a go I thought it was my phone to start with Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted November 26, 2015 Author Share Posted November 26, 2015 Problem solved I have space invaders under my hood not : my battery in the fob is done sometimes it's the simplest thing that's the answer Quote Link to comment Share on other sites More sharing options...
