Guest Big red johnson Posted November 13, 2015 Share Posted November 13, 2015 Hi all, got a weird one (I think), during driving the car suddenly drops all boost, won't change gear and then the o/d light and the slip cont off lights start flashing, this stops me from putting the car into manual mode and also wipes out the traction control. I've just wiped the ecu of any old error codes and recreated the problem, stopped and did an ecu error code test but it shows no error codes. Any thoughts? Looking at prior threads regarding similar issues they have always given an error code. I would have thought this kind of thing would have thrown up a error code of some description. (Car is a jap tt auto) Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Tyson Posted November 13, 2015 Share Posted November 13, 2015 I'm not sure if it would but does it have a speed converter ? These seem to cause all manner of electrical gremlins. Quote Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 13, 2015 Share Posted November 13, 2015 Hmm I believe it does, no idea where it is or how to test if it's working properly though Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 14, 2015 Share Posted November 14, 2015 Have you, or anyone else fiddled with ANYTHING on the car recently, however unrelated that fiddling may appear to be? Quote Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 14, 2015 Share Posted November 14, 2015 Nope nothing, the thing that's confusing me about it all is the lack of an error code. Quote Link to comment Share on other sites More sharing options...
David P Posted November 14, 2015 Share Posted November 14, 2015 Check that the bulb that should show an error code actually functions? Quote Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 14, 2015 Share Posted November 14, 2015 The management light flashes continuously when I bridge the diagnostics ports. Quote Link to comment Share on other sites More sharing options...
David P Posted November 14, 2015 Share Posted November 14, 2015 Take a look behind the odometer and see if there's any after market wiring, as has been mentioned above, many strange happenings can result from these tinkerings. Quote Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 14, 2015 Share Posted November 14, 2015 Will do when I get a free hour or so, not overly bothered, just annoying when it happens and losing all power for a few seconds. Quote Link to comment Share on other sites More sharing options...
David P Posted November 14, 2015 Share Posted November 14, 2015 When you do resolve this please post up the fix for reference, these Gremlins are turning up often just lately. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 14, 2015 Share Posted November 14, 2015 I would check the main ecu connector, and the ecu engine ground wires under the intake manifold, and (I think...) on the body shell to the left of the main ecu. The workshop manual shows their locations. Quote Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 14, 2015 Share Posted November 14, 2015 I've got an emanage blue under the passenger seat as well, I'll check the connections there too. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 14, 2015 Share Posted November 14, 2015 Oh, right, all bets are off then, could well be something to do with that thing! Especially if its wired like many I see Quote Link to comment Share on other sites More sharing options...
