Swampy442 Posted November 10, 2015 Share Posted November 10, 2015 OK so Ill open with - Does the J spec Supra (specifically the VVTI engines) cruise control limit the car to 110km/h? If so does a speedo convertor remove that limit? If not, does anyone know of a workaround to delimit the cruise? I seem to remember a mod you can do with Soarers to alter the cruise control but for the life of me cant find the info anywhere. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted November 10, 2015 Share Posted November 10, 2015 Not VVTI, but when I delimited (took the 110mph limit off) my J-Spec it also delimited the cruise as I sat once on a private road at 130 on cruise. Quote Link to comment Share on other sites More sharing options...
Alex_GT Posted November 10, 2015 Share Posted November 10, 2015 I didn't know the VVTi cars had cruise control, was it an option or only available on certain models? Quote Link to comment Share on other sites More sharing options...
David P Posted November 10, 2015 Share Posted November 10, 2015 If the cruise control circuit is same as non VVTI, the way to do it is to swap the J spec cruise control ECU for a U.K. spec cruise control ECU. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 10, 2015 Author Share Posted November 10, 2015 Its not for a Supra, but I assume the set up will be the same. I know on Mk2 Aristos a speedo convertor doesnt remove the cruise limit, but it does on Mk1's. I think its because the ECU architecture changed. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 10, 2015 Share Posted November 10, 2015 None of the vvti Supras have cruise control. And from the little research I've done, the vvti Aristo cruise control system is totally different and incompatible with the non vvti. The only decent solution I could find was to install a Syvecs Quote Link to comment Share on other sites More sharing options...
