kevin smith Posted November 9, 2015 Share Posted November 9, 2015 (edited) My OD light flashes on and off, not all the time though any idea's Thanks Edited November 9, 2015 by kevin smith Error (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted November 9, 2015 Share Posted November 9, 2015 Check for fault codes, maybe you'll find a 42? Quote Link to comment Share on other sites More sharing options...
kevin smith Posted November 10, 2015 Author Share Posted November 10, 2015 Thanks I read the article, so need too change no1 speed sensor, is that correct. Quote Link to comment Share on other sites More sharing options...
kevin smith Posted November 10, 2015 Author Share Posted November 10, 2015 I am not too mechanically minded, but the car has had the speedo converted to MPH, I don't have the tool's to check error codes. Does anyone know a suitable mechanic in Essex that I could go to. Quote Link to comment Share on other sites More sharing options...
Ric Posted November 10, 2015 Share Posted November 10, 2015 You dont need a tool, you need a paperclip and to perhaps use the search box on here.. Again, in the FAQ section http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes Quote Link to comment Share on other sites More sharing options...
David P Posted November 10, 2015 Share Posted November 10, 2015 IF it is an error code 42, first check the joints on the speedo conversion, if that doesn't fix it, the pink wire mod will. http://www.mkivsupra.net/vbb/showthread.php?72588-Code-42-Fix&highlight=pink+wire+mod Quote Link to comment Share on other sites More sharing options...
ronttuk Posted November 10, 2015 Share Posted November 10, 2015 where is no1 speed sensor ?? Quote Link to comment Share on other sites More sharing options...
ronttuk Posted November 11, 2015 Share Posted November 11, 2015 No one know ??? Quote Link to comment Share on other sites More sharing options...
David P Posted November 11, 2015 Share Posted November 11, 2015 A couple of minutes looking at the Workshop Manual would have saved you having to wait a day to find out that it is on the side of the transmission a little further forwards than the no. 2 speed sensor. Quote Link to comment Share on other sites More sharing options...
ronttuk Posted November 13, 2015 Share Posted November 13, 2015 Now i know its on the gearbox ill look at repair manual thanks for your help. Quote Link to comment Share on other sites More sharing options...
David P Posted November 13, 2015 Share Posted November 13, 2015 I doubt the sensor will be the problem, more likely as I have already informed you. Quote Link to comment Share on other sites More sharing options...
