Nur spec r/rx?
RobAce
Is there any difference in performance?
The NUR R is one of the more free flowing exhaust designs given it's 3" pipework and because it follows pretty much a straight path from the 2nd cat to the rear bumper, the NUR RX is the same design but with the extra middle silencer, so any performance difference will be marginal. If you're running the stock turbos and decats, then any slight difference in flow will be negated by the restrictor ring anyway.
