Mark D Posted April 2, 2003 Share Posted April 2, 2003 I know this has been covered before as I have read all the threads after using the search engine. The general consensus was that you can buy an hb4 or 9005 bulb to fit in the dipped light of a J-spec. Most mentioned that it needed modification to make it fit, but noone wrote how they got on with the modification. Which is the best dipped beam bulb to buy and what is the best method to modify it to fit in a J-spec headlight? Also, are any of you guys having any trouble reading all the posts that come up in each thread? At the moment if it says there are 7 postings in one threead then I can only see about 3. Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted April 3, 2003 Share Posted April 3, 2003 Most mentioned that it needed modification to make it fit, but noone wrote how they got on with the modification I think because it was so simple no one mentioned it. IT's just a case of filing away some of the mounting plate to make the bulb fit. I don't think it's hard. Just buy a bulb and offer it up. are any of you guys having any trouble reading all the posts that come up Try checking the following is set in your browser. (Assuming it's IE) Tools:Internet Options:Temporary Internet Files: Settings Check for newer pages,..... ensure the (AUTOMATICALLY) radio button is ticked. Regards Pete Quote Link to comment Share on other sites More sharing options...
Mark D Posted April 3, 2003 Author Share Posted April 3, 2003 Thanks a lot Pete Unfortunately my IE no longer works so I am forced to use Netscape. I have been trying to get hold of you at the office for the last couple of days. Please check the answerphone for my mobile number. Mark Quote Link to comment Share on other sites More sharing options...
