r2ck_p Posted November 3, 2015 Share Posted November 3, 2015 (edited) Hi guys, I am getting an intermittent loud noise on start up and for a up to 5-8 seconds afterwards. I initially thought it might be to do with the power steering but the noise will happen even if the car stays stationary after start up. In order to solve the issue, I firstly checked my Power Steering fluid which was on the very low side (minimal reading on dip stick). Thanks to some forum member I noticed a leak from the O-Ring on the pipe that goes from the Power Steering reservoir to the pump. The O-ring was replaced, along with both the hoses which go to/from the reservoir. New P/S fluid was put in and I did the whole left/right turning whilst front wheels in the air. This didn't seem to resolve the noise. I finally managed to get a recording of the noise this morning so hopefully it will help. (Video Lnk Blow) Let me know what you guys think. https://youtu.be/qujIS4PYWcw Cheers Edited November 3, 2015 by r2ck_p (see edit history) Quote Link to comment Share on other sites More sharing options...
trebor69 Posted November 3, 2015 Share Posted November 3, 2015 Have you done the tippex test on the crank pulley? Quote Link to comment Share on other sites More sharing options...
Abz Posted November 3, 2015 Share Posted November 3, 2015 Yep, that is your crank pulley about to fall off!! Quote Link to comment Share on other sites More sharing options...
Havard Posted November 3, 2015 Share Posted November 3, 2015 Yep, that is your crank pulley about to fall off!! This. New pulley required Rick. Good job they are cheap.......but not half as bad as having it fly all around your engine bay at speed. H. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 4, 2015 Share Posted November 4, 2015 "Would you recommend one of them ebay solid pulleys?" No. Just before you ask Quote Link to comment Share on other sites More sharing options...
r2ck_p Posted November 4, 2015 Author Share Posted November 4, 2015 Thanks guys, really appreciate the help. I have just ordered a genuine Toyota Crank Pulley from TCB Parts - £247.88 including VAT and delivery. Must better then Toyota direct prices. Just need to get some prices of fitting it now. Quote Link to comment Share on other sites More sharing options...
