Aftermarket inlet manifolds.
FOSTA
Are you putting the battery in the boot? As most need the battery relocating.
The Greddy cast plenum looks like the best value for money. The Veilside ones are a work of art, but are no longer available new and rarely come up for sale.
Yeah the battery will be going in the boot fella. ;)
- - - Updated - - -
I'll be fitting my Greddy one soon :)
What's the greddy one? Where do you get them from?
An aftermarket intake manifold isnt usually needed unless you are running close to 1000hp and most come with a throttle body which is huge, and that makes daily driving harder. They look nice though.
I'm running a Titan Motorsports modified stock intake manifold which has had the plenum changed like mwilkinson suggested above. I'm running the stock 65mm throttle body and almost 1300hp, so the stock TB isnt much of a restriction even at those power levels. Would be fun to test a 75mm to see if there's a gain, but most likely not very big.
Edited by Krister (see edit history)
