blackrzs Posted November 3, 2015 Share Posted November 3, 2015 I recently converted to single turbo and my downpipe doesn't have a 2 bolt lambda sensor flange only the screw type one...does anyone know an alternative screw type sensor i can use Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 3, 2015 Share Posted November 3, 2015 So you want to run a std type lambda on what ECU? I would presume you have a stand alone or piggyback at a minimum? for a single turbo, in which case why not run a wide-band set up? and run a simulated signal to the piggyback, failing that try just lambda and look for the appropriate threaded universal sensor. Quote Link to comment Share on other sites More sharing options...
blackrzs Posted November 5, 2015 Author Share Posted November 5, 2015 So you want to run a std type lambda on what ECU? I would presume you have a stand alone or piggyback at a minimum? for a single turbo, in which case why not run a wide-band set up? and run a simulated signal to the piggyback, failing that try just lambda and look for the appropriate threaded universal sensor. a wideband is what i need..i'v been told that a bosch lsu 4.9 O2 sensor is fine to work with.yes i will be running a standalone Quote Link to comment Share on other sites More sharing options...
