Jam127 Posted November 2, 2015 Share Posted November 2, 2015 Ok so iv never seen a car do this before.. When the car is on idle with nothing turned on - fine But when i turn my sidelights on or rear demister the revs climb and fall between 1-1.8k so it seems whenever it requires more power. The revs are consistant and it seems to be pulling alot of air through the air filter. Iv checked voltage coming from battery amd alternator, earths (i have an earthing kit fitted) checked vac pipes and checked battery terminals etc all seem good. I dont have a clue where to go next Thanks, Jamie Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted November 2, 2015 Share Posted November 2, 2015 Are the battery terminals clean and tight Quote Link to comment Share on other sites More sharing options...
Jam127 Posted November 2, 2015 Author Share Posted November 2, 2015 Yeap checked them. I did forget to mention i only noticed this problem after i changed to iridium plugs and a vaccum pipe came off a small black box on the intake which made it run lumpy smokey etc, the pipe is back on and the plugs are changed back because they came out white, bloody waste of £50! . When changing back to copper i double checked everythig i could have disturbed and nothing seems out of place Quote Link to comment Share on other sites More sharing options...
