SupraP-Z Posted November 2, 2015 Share Posted November 2, 2015 So i bought some new shoes for the supe chucked them on and eventually needed to replace the front two tyres which i did for brand new jobbies a couple of weeks ago. When i bought the rims one of them had a leaky valve, so i had this replaced over the weekend...but after a couple of days the tyre has gone down again. It is losing pressure slowly and needs to be pumped up every day or two. Im led to believe this may possibly (hopefully not) point to a cracked rim?! Quote Link to comment Share on other sites More sharing options...
mattdavies Posted November 2, 2015 Share Posted November 2, 2015 Spray the whole wheel generously with a high concentrate of washing up liquid solution and you should see the bubbles forming where the air is leaking from, either that or you take the wheel off and put it in the bath !! Quote Link to comment Share on other sites More sharing options...
Al Massey Posted November 2, 2015 Share Posted November 2, 2015 As above This could be down to the valve, tyre, tyre not sitting right on the bead, if split rims could be a leak somewhere or a crack. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 2, 2015 Share Posted November 2, 2015 All of the above, or the rim is pourous Quote Link to comment Share on other sites More sharing options...
