cziko Posted November 1, 2015 Share Posted November 1, 2015 Hi for sale a few parts all price posted but + paypal fees World wide shipping is avalible or local collection in Leighton Buzzard LU73WJ Triple plate HKS clutch in good condition 599pounds [ATTACH=CONFIG]215964[/ATTACH] [ATTACH=CONFIG]215965[/ATTACH] [ATTACH=CONFIG]215966[/ATTACH] [ATTACH=CONFIG]215967[/ATTACH] Supra turbo a/t Indiglo cluster 140pounds [ATTACH=CONFIG]215968[/ATTACH] 1JZGTE custom built turbo manifold T3 flange and tial 44 waste flange outlet This strong manifold is welded on of good stainless steel 0,2mm not 0,1 like cheap chinese products which breaks after a month of use Built by a company with more than 10 years experience building own custom exhaust systems for motorsports 599pounds [ATTACH=CONFIG]207682[/ATTACH] [ATTACH=CONFIG]207683[/ATTACH] Very rare BREMBO F40 Big Breake Kit 340mm model F40 for Toyota Supra MKIV compatible with lexus gs300 jzs147 jzs160 gs300 gs400 gs430 – this set is proffesionaly remanufactured, brake calipers were sandblasted and powder coated in red colour. Brake pads are made by StopTech and done only 1000 miles so they reach perfect match with brake discs. Brake discs has 31,1mm thickness (new ones are 32mm) so they have more than 50% of “life”. Works extremally good – I never had any probs with braking from 270 km/h to 0 km/h !!!! KIT INCLUDES 2 x Red 4 Piston F40 Calipers BREMBO 2 x Caliper Adapters 2 x Slotted 2 piece Rotors 340x32 (Fit on 17" Wheel) 2 x Stainless Steel Brake Lines Pad set STOP TECH SETO OF ALL BOLTS 699 pounds posted [ATTACH=CONFIG]206299[/ATTACH] [ATTACH=CONFIG]206300[/ATTACH] Sway bars TANABE SUSTEC SOLD Cusco front and rear strut bar -SOLD Legendary special turbo HKS T45S 1.04 a/r biggest in the family t45s and it's good to 900hp+ !! wery rare stuff !! Used but still in excellent condition Absolutly no shaft play and oil lakes , it's like new 699 pounds posted [ATTACH=CONFIG]206307[/ATTACH] [ATTACH=CONFIG]206308[/ATTACH] [ATTACH=CONFIG]206309[/ATTACH] JDM Alloy Wheels set (without tire) 2pieces RACING HART C4 19x10,5 et26 (deep dish 4inch) & 19x9 et22 very nice wheels with aggressive fitment Never repaired only fresh blasted and powder coated Very strong wheels not cheap china sheet 699pounds [ATTACH=CONFIG]207685[/ATTACH] [ATTACH=CONFIG]207686[/ATTACH] all price is for a small negotiations HKS DLI SOLD [ATTACH=CONFIG]207264[/ATTACH] Link to comment Share on other sites More sharing options...
Ric Posted November 2, 2015 Share Posted November 2, 2015 I will take the passenger airbag please. Can you please repost the photo of the airbag along with a piece of paper with your username and the date? You're a new user (in terms of posts not join date) i want to make sure you have the parts Link to comment Share on other sites More sharing options...
Scott Posted November 2, 2015 Share Posted November 2, 2015 I will take the passenger airbag please. Can you please repost the photo of the airbag along with a piece of paper with your username and the date? You're a new user (in terms of posts not join date) i want to make sure you have the parts Is it not just the cover? Link to comment Share on other sites More sharing options...
cziko Posted November 2, 2015 Author Share Posted November 2, 2015 It's only a cover not coplete airbag Link to comment Share on other sites More sharing options...
Ric Posted November 2, 2015 Share Posted November 2, 2015 How does this fit to a normal airbag? Or does it just sit in the hole? Link to comment Share on other sites More sharing options...
drift_bear Posted November 2, 2015 Share Posted November 2, 2015 I've been searching ages for an airbag cover, but that seems a bit expensive IMHO Link to comment Share on other sites More sharing options...
cziko Posted November 2, 2015 Author Share Posted November 2, 2015 fits good to old airbag http://supraforums.com/forum/showthread.php?499857-air-bag-cover I am waiting for proposals Link to comment Share on other sites More sharing options...
Parm_93 Posted November 2, 2015 Share Posted November 2, 2015 What's your best price for the Strut brace? Link to comment Share on other sites More sharing options...
Ric Posted November 2, 2015 Share Posted November 2, 2015 Im confused. If it's just a cover, why does it have a yellow SRS lead? Does the old cover come off the airbag? the last time i looked it looks moulded to it? Or is this meant to go in the place of an airbag and uses the connector to fool the ecu into it being present? Link to comment Share on other sites More sharing options...
cziko Posted November 2, 2015 Author Share Posted November 2, 2015 What's your best price for the Strut brace? I am waiting for proposals Im confused. If it's just a cover, why does it have a yellow SRS lead? Does the old cover come off the airbag? the last time i looked it looks moulded to it? Or is this meant to go in the place of an airbag and uses the connector to fool the ecu into it being present? do you have passenger airbag on your car ?? sells only the cover airbag sold a long time ago Link to comment Share on other sites More sharing options...
Ric Posted November 3, 2015 Share Posted November 3, 2015 I have a passenger airbag yes. But as i said, the front cover looks moulded to the airbag, does not look removeable? Link to comment Share on other sites More sharing options...
Scott Posted November 3, 2015 Share Posted November 3, 2015 I have a passenger airbag yes. But as i said, the front cover looks moulded to the airbag, does not look removeable? From what I've read it should unbolt? I have mine in the garage, will check for you in a bit. Link to comment Share on other sites More sharing options...
Scott Posted November 3, 2015 Share Posted November 3, 2015 There's 4 bolts holding it onto a bracket at the top. It appears that when you undo them, it should tilt out and detach from the bottom. I can't be 100% certain but it definitely looks detachable to me. My cover is slightly different though. It doesn't have "Supra" on it, it has SRS Airbag. Link to comment Share on other sites More sharing options...
j_jza80 Posted November 3, 2015 Share Posted November 3, 2015 I think that's a pre facelift airbag from a UK spec car. Link to comment Share on other sites More sharing options...
Ric Posted November 3, 2015 Share Posted November 3, 2015 I see, i didnt even notice that on my airbag, not something i was looking for. My airbag is on my Pre-Facelift. Would this facelift cover fit? If so, ill still take it! Link to comment Share on other sites More sharing options...
cziko Posted November 6, 2015 Author Share Posted November 6, 2015 New stuff on list Bump Link to comment Share on other sites More sharing options...
Scott Posted November 6, 2015 Share Posted November 6, 2015 Interested in this part shipped.... http://www.mkivsupra.net/vbb/attachment.php?attachmentid=206334&d=1446419591 If you're selling separate and it includes the fan guide. Link to comment Share on other sites More sharing options...
jonc Posted November 7, 2015 Share Posted November 7, 2015 PMed mate Link to comment Share on other sites More sharing options...
cziko Posted December 4, 2015 Author Share Posted December 4, 2015 pm checked Link to comment Share on other sites More sharing options...
cziko Posted December 4, 2015 Author Share Posted December 4, 2015 Interested in this part shipped.... http://www.mkivsupra.net/vbb/attachment.php?attachmentid=206334&d=1446419591 If you're selling separate and it includes the fan guide. 33pounds posted Link to comment Share on other sites More sharing options...
Ric Posted December 4, 2015 Share Posted December 4, 2015 Just so people are aware. I bought the airbag cover from Cziko and after 3-4 weeks he told me he cannot find the item. No dispute needed, communication was good and Cziko refunded when he said he would. Just maybe worth, if you're buying.. for Cziko to check he can find it before sending the cash. Link to comment Share on other sites More sharing options...
cziko Posted December 4, 2015 Author Share Posted December 4, 2015 hehe correct now am check and all the stuff is in magazine and in such a situation only Lossy person is me because accepting and returning lost 5pounds - - - Updated - - - bump for new price and stuff Link to comment Share on other sites More sharing options...
jonc Posted December 10, 2015 Share Posted December 10, 2015 Bought some stuff from Cziko and all was delivered within a week of purchase. He was even kind enough to hold the items in reserve until I could afford to buy them. Trusted seller even if he is a newbie. Cheers Cziko Link to comment Share on other sites More sharing options...
cziko Posted December 28, 2015 Author Share Posted December 28, 2015 bump ! Link to comment Share on other sites More sharing options...
kevin smith Posted December 29, 2015 Share Posted December 29, 2015 I will take the front brace if tin still available. Link to comment Share on other sites More sharing options...
