Airbag harness removal - is it safe to do so?
cered
My car's a facelift so alreayd has it, the harness is for the older to newer Toyota airbag harnesses :(
My car is facelift too and didn't have it.
Worst case scenario you could just cut off the plug and put it on the new airbag? Needs a voltage across it to activate the bag, just make sure you are well grounded and haven't built up any static :)
Yeah I think that's how it'll have to be... Gotta work out which wires which though
Yaris airbag: yellow/red and yellow/blue
Supr: red and blue
I know the colours match up but I'm not confident...
Take this as what you will, I am only giving a bit of guidance here.....
If you look at the connection on both airbags, the left pin will always be the left pin.... and the right pin will always be the right pin. To identify which is left and which is right, the connector clip should be viewed as "up". I'm talking about the actual plug here, rather than the wires going into the airbag itself.
Does that make sense to you?
In answer to your original question yes it is safe to remove that fly loom from the airbag unit. Should just unclip upwards as it is in the photo.
Airbags are a 12V trigger - pos/neg, I know this from setting them off for fun (alot of fun), putting a battery onto one made it shoot up about 50ft in the air. I'm not for a moment suggesting you should do this for entertainment. Not for a moment.
Any way to tell which wire is positive/negative? :p
I completely understand your concern and I will not be playing silly buggers with an airbag... My 12v batteries will be stored away from the whoopee cushion of death
Same here, I changed from a 4 spoke wheel to a carbon wheel. Keron bought a harness adapter from Toyota and fitted using this to retain the airbag function.
As that airbag is it's completely harmless there's no electricity around to be able to trigger it. What also happens in a lot of modern vehicles is it releases a safety tab so even if you put a feed to it without spreading the tab out again it still wouldn't go off. Even when an airbag is in circuit on the vehicle it's perfectly same as the system is always a constant earth. The only thing that will trigger the live is one of the crash sensors detecting an impact. Airbags are a lot safer than people think if I'm honest.
