raddys Posted October 28, 2015 Share Posted October 28, 2015 As above, will they fit, I don't want to buy them and find out they don't fit, I can see standard specs online but not that max that can be run? Any help much appreciated Thanks Quote Link to comment Share on other sites More sharing options...
ashloys Posted October 28, 2015 Share Posted October 28, 2015 Yeh they will dude. Depends what tyre size and if you've any camber at the front though. But I was planning on getting 18x9.5 ET30 fronts and running 225/235 tyres with some negative camber. Rears will be 100% as I'm running 18x9.5 ET25 on the rear of mine now! Quote Link to comment Share on other sites More sharing options...
Scooter Posted October 28, 2015 Share Posted October 28, 2015 They will fit on the rear..... Quote Link to comment Share on other sites More sharing options...
raddys Posted October 28, 2015 Author Share Posted October 28, 2015 The tyres are 245/40, will they rub on the front? Quote Link to comment Share on other sites More sharing options...
jim Posted October 28, 2015 Share Posted October 28, 2015 Probably bud, is the car lowered? For reference, these are 18 x 8 et 27 on the front of mine (with 235/40 tyres), 18 x 9.5 et 38 will stick out 8mm further. I'm on coilovers though and lowered a right bit, I had to fold the tabs in the arches back and they rubbed on full lock. Quote Link to comment Share on other sites More sharing options...
raddys Posted October 28, 2015 Author Share Posted October 28, 2015 No car not lowered atm, and yes I think it will be a little bit wide on the fronts, oh well, the search continues, ps nice supra jim Quote Link to comment Share on other sites More sharing options...
Supraleeturbo Posted October 29, 2015 Share Posted October 29, 2015 My pal is running 9.5 et 38 on the front with a 245 tyre no problem Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted October 29, 2015 Share Posted October 29, 2015 The new wheels we've ordered are 18x9.5J ET37 and ive seen pictures of them clear UK/US brakes on standard front arches. It also depends on the style of wheel aswell. Quote Link to comment Share on other sites More sharing options...
raddys Posted October 29, 2015 Author Share Posted October 29, 2015 These are the wheels, 5x114.3 18x9.5 .. 245/40-18, so you lads both reckon they will fit (I'm still on standard suspension atm as I've only had the car a couple months) Quote Link to comment Share on other sites More sharing options...
Rywalls Posted October 29, 2015 Share Posted October 29, 2015 I'm running rota GTR's 18" 9.5J ET 30 with 255/35/18 front and 265/35/18 rear. Car is on standard shocks but has tein s tech lowering springs, rears are fine, the fronts stick out a little bit more but they don't catch on full lock or anything and just clear UK brakes. I was under the impression that the lower the ET number the further they stick out from the arch as im sure ive read that the stock wheels are ET 50. I have some coilovers going on soon and just had the arches rolled so may have to get smaller stretched tyres and abit camber to help it fit but apart from that ive had no dramas Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted October 29, 2015 Share Posted October 29, 2015 Just have the arches rolled or cut job done. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted October 29, 2015 Share Posted October 29, 2015 (edited) What about these, would they fit on stock arches Would these fit 5x114.3 8.5" front ET 20 10. rear ET 12 Edited October 30, 2015 by sidewaysdan (see edit history) Quote Link to comment Share on other sites More sharing options...
SoarerMan Posted October 30, 2015 Share Posted October 30, 2015 I ran a 225/40R18 Front & 245/40R18 Rear with 18x9 & 18x10.5 et20 I had to roll the rear arches with coilovers fitted. The fronts rubbed inner liners on full lock only. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted October 30, 2015 Share Posted October 30, 2015 (edited) It's the et 12 I'm worried about The fronts are 225 40 18 8.5j et20 The rears are 255 35 18 10j et12 Edited October 30, 2015 by sidewaysdan (see edit history) Quote Link to comment Share on other sites More sharing options...
jim Posted October 30, 2015 Share Posted October 30, 2015 10.5 et 20 will stick out 25mm more than mine (pic above), you'll struggle to get them to fit (but probably could be made fit with arch work and a stretched tyre). Do you know what the width and offsets of your current set up is? http://www.willtheyfit.com is brilliant for working out fitment but you need to know your current set up for it to be meaningful. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted October 30, 2015 Share Posted October 30, 2015 Not sure if they guy has given me the right et for them As the front are et20 8.5 a and the rear Et12 10j I'll have to look at mine Quote Link to comment Share on other sites More sharing options...
