HarleyFDMD Posted October 27, 2015 Share Posted October 27, 2015 I need some advice/help with V bands please. I have a V band precision wastegate with a 46/47ish mm manifold side ID. I need to buy a V band flange which will be welded onto the manifold for the wastegate but I'm struggling to find one with exactly a 47mm ID, how important is it that it's exact? Could I use a 45mm ID flange? Or would that create a hot spot/burn the wastegate valve atall for not using its entire surface area? Struggling to explain it abit but hope someone will understand what I mean. Cheers Quote Link to comment Share on other sites More sharing options...
black_widow87 Posted October 28, 2015 Share Posted October 28, 2015 If bought new it should have come with one in the box. Mine did. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 28, 2015 Share Posted October 28, 2015 I assume it's the 46mm wastegate you have, on the Precision website they list the part numbers for the flange. http://www.precisionturbo.net/products/details/Precision-Turbo-and-Engine-PW46-External-Wastegate--46mm-/26 http://www.precisionturbo.net/tech/instruction-manuals/PTE-PW46-Wastegate-Instructions.pdf Quote Link to comment Share on other sites More sharing options...
