Headlight Adjustment?
IanK
My J-Spec has standard plastic clusters (which are in a very good, non yelow condition) but has had a HID kit fitted when in Japan.
They give a very nice bright light but unfortunately are pointing far to high and i keep getting flashed by other drivers. :giveup:
Ive searched and found a post regarding what adjusters do what.
http://www.mkivsupra.net/vbb/showthread.php?t=39161&highlight=adjusting+headlights
http://www.mkivsupra.net/vbb/showthread.php?t=33105&highlight=adjusting+headlights
I parked my car facing a wall at turned the adjustment rods but non of them seem to do anything when ? :help:
Can anyone confirm for definate that the inside adjuster is for the height and which direction does it need rotating to lower the beam?
3 adjusters.
If you turn the bottom one anti-clockwise it will lower the headlight beam.
The adjusters have a fine thread, so you'll have to turn it quite a bit to see any difference.
Adjuster nearest wing - clockwise will lower fog light.
Middle adjuster - clockwise will move headlight towards centre line of car
