Headlight Induction Conversion
lockys96
has anyone have any info on how this is done, or can it be purchased,
i have seen a number of cars which have the front headlight cut out, forcing air to the filter
as below
Someone must have done this, any info?
sorry couldnt find it anywhere on the forum,
Si
Get a really big powerful laser link from a Mech Warrior or something. Line it all up in a Black and Decker Workmate (use a spirit level! - You don't want to hit it at an angle!)
Then pow! - Fire a nice neat cut laser hole straight through your light.
Don't forget to remove the light from your car first of course... and don't stand behind it.
:D
I asked the owner of that car how it was done.. its a bit tricky to make it look good...
- find some plastic pipe approx the same size as the main beam light
- remove the main bean light and cut back enough plastic so the pipe goes in
- start cutting one end of the pipe at an angle, so that when it is inserted it comes flush against the back of the plastic headlamp
- with a marker pen draw a line around the area where the pipe meets the plastic
- Carefully(!!!) cut the hold in the headlamp where you marked it out (This can be done without splitting the unit apart, but would be easier if you did.
- Fix the pipe in place at the rear with some glue (eg. Araldite)
- Trim up and tidy the front. He had glued some plastic trim over the rough edges
If anyone is interested i have a pair of facelift lights refurbished with the induction hole profesionally made, if there is enought interest as people dont want to attempt this as they could cause damage/mess-up their own lights i can offer these on an exchange or non-exchange service. It is a complicated and risky procedure and as far as im aware they are fully legal and you will still pass your MOT with them in.
Details by P'm
James
