binfieldx Posted October 23, 2015 Share Posted October 23, 2015 (edited) Interesting run Flywheel At the wheels http://i108.photobucket.com/albums/n21/binnie_2006/20151023_151539_zpscbgpvosr.jpg Specs should be... Jspec TT 6sp BPU running in TTC All stock except Blitz fmic Blitz air filter Kakimoto fully decatted Aftermarket LSD Edited October 23, 2015 by binfieldx (see edit history) Quote Link to comment Share on other sites More sharing options...
Fitz Posted October 23, 2015 Share Posted October 23, 2015 AFR looks spot on as does boost Quote Link to comment Share on other sites More sharing options...
Admiral Donuts Posted October 23, 2015 Share Posted October 23, 2015 Great results Tom I bet your well chuffed mate! Quote Link to comment Share on other sites More sharing options...
binfieldx Posted October 23, 2015 Author Share Posted October 23, 2015 Not even sure what bhp we are supposed to claim when people ask now, flywheel or at the wheels? Quote Link to comment Share on other sites More sharing options...
GazDoran Posted October 23, 2015 Share Posted October 23, 2015 Sorry to ask what is probably a stupid question, but what is meant by running in TTC?? Also, what was the difference in the 2 runs to get such different figures? Quote Link to comment Share on other sites More sharing options...
Scott Posted October 23, 2015 Share Posted October 23, 2015 Figures look optimistic but at least you have a nice yardstick to compare others at the same dyno with Boost looks good but fuelling looks a little lean. Was it being measured at the exhaust tip, wondering how much that effects the reading. Quote Link to comment Share on other sites More sharing options...
binfieldx Posted October 23, 2015 Author Share Posted October 23, 2015 It was the dyno reccomended by lee @ srd so im happy with it i believe they just stick a sensor a slight way in the pipe for the fueling. Also TTC is true turbo conversion where they are setup to both come on at the same time rather than sequential. Top figure is flywheel hp and bottom is figure at the wheels Quote Link to comment Share on other sites More sharing options...
GazDoran Posted October 23, 2015 Share Posted October 23, 2015 It was the dyno reccomended by lee @ srd so im happy with it i believe they just stick a sensor a slight way in the pipe for the fueling. Also TTC is true turbo conversion where they are setup to both come on at the same time rather than sequential. Top figure is flywheel hp and bottom is figure at the wheels Ahhh...interesting. Thanks the for the reply! Quote Link to comment Share on other sites More sharing options...
Admiral Donuts Posted October 23, 2015 Share Posted October 23, 2015 I made 432.1bhp at BPU running hybrids Quote Link to comment Share on other sites More sharing options...
binfieldx Posted October 23, 2015 Author Share Posted October 23, 2015 Makes me wonder how i got 453 Quote Link to comment Share on other sites More sharing options...
Wez Posted October 24, 2015 Share Posted October 24, 2015 Makes me wonder how i got 453 Possibly low BP and high AT values, this would raise the calculated figure that are shown on the graphs Quote Link to comment Share on other sites More sharing options...
binfieldx Posted October 24, 2015 Author Share Posted October 24, 2015 possibly low bp and high at values, this would raise the calculated figure that are shown on the graphs bp/at? Quote Link to comment Share on other sites More sharing options...
Wez Posted October 24, 2015 Share Posted October 24, 2015 Barometric Pressure and Air Temp. Some info in here if you fancy a read http://www.jkm.org.uk/performance/dynotesting.htm Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 24, 2015 Share Posted October 24, 2015 I would doubt that Barometric Pressure and Air Temp are going to account for a 53BHP increase over any other dyno print out I have seen for a BPU Supra, and a 73BHP drive train loss is a little excessive to, TTC mode should not account for any increase in max power figure. Quote Link to comment Share on other sites More sharing options...
binfieldx Posted October 24, 2015 Author Share Posted October 24, 2015 (edited) Its the same dyno everyone else uses. I assume internals are standard havent been told otherwise. I thought WHP was around 15% less than flywheel which works out to 68hp less at wheels from my 453 which is quite close to 73bhp..? Edited October 24, 2015 by binfieldx (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted October 24, 2015 Share Posted October 24, 2015 Try a run on a different day and see if the results are comparable. Even better, pop along with some other members to have a mini shootout. That way you'll know if you have an exceptionally powerful car Quote Link to comment Share on other sites More sharing options...
binfieldx Posted October 24, 2015 Author Share Posted October 24, 2015 Its clearly my crazy japanese myth mods that came on the import like my battery voltage regulator i thought 450 was around the top end of BPU mods anyway? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 24, 2015 Share Posted October 24, 2015 Its the same dyno everyone else uses. I assume internals are standard havent been told otherwise. I thought WHP was around 15% less than flywheel which works out to 68hp less at wheels from my 453 which is quite close to 73bhp..? I am going back quite a few years when quoting not seeing any more than 400BHP form a BPU motor, even with a bigger FMIC, exhaust etc, I think there was once a claim of 420BHP but it was unsubstantiated, in theory the injectors shouldn't even be able to supply that BHP, but the std ECU does run the injectors at 100% DC when a airflow voltage of over 4-4.3V so max fuel is available, but I wouldn't expect max flow rate from a 15 year old fuel system. I do wonder if an aging knock sensor has a part to play, as they do wear, and also pick up more engine noise on a worn or tuned engine, so it makes me wonder if some Supras are able to make more power because the knock sensor is not so sensitive and not pulling ignition timing at the top end, trouble is it also something unsubstantiated as I don't know of anyone who has been able to monitor the std ECU. Quote Link to comment Share on other sites More sharing options...
chazuk Posted October 24, 2015 Share Posted October 24, 2015 What gear was it run in ? Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted October 24, 2015 Share Posted October 24, 2015 I am going back quite a few years when quoting not seeing any more than 400BHP form a BPU motor, even with a bigger FMIC, exhaust etc, I think there was once a claim of 420BHP but it was unsubstantiated, in theory the injectors shouldn't even be able to supply that BHP, but the std ECU does run the injectors at 100% DC when a airflow voltage of over 4-4.3V so max fuel is available, but I wouldn't expect max flow rate from a 15 year old fuel system. I do wonder if an aging knock sensor has a part to play, as they do wear, and also pick up more engine noise on a worn or tuned engine, so it makes me wonder if some Supras are able to make more power because the knock sensor is not so sensitive and not pulling ignition timing at the top end, trouble is it also something unsubstantiated as I don't know of anyone who has been able to monitor the std ECU. A lot of people recently have been making more that 400 at bpu. I haven't seen one as high as 450 but mine made 421 and safcdixon made 431 about 2 months ago. Quote Link to comment Share on other sites More sharing options...
Wez Posted October 24, 2015 Share Posted October 24, 2015 I would doubt that Barometric Pressure and Air Temp are going to account for a 53BHP increase over any other dyno print out I have seen for a BPU Supra, and a 73BHP drive train loss is a little excessive to, TTC mode should not account for any increase in max power figure. I didnt say it added 53bhp I am saying that incorrect values can affect the output calculation, as does strapping technique, tire pressure etc etc. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 24, 2015 Share Posted October 24, 2015 Many many years ago now, at 1.2 bpu on a 45Kkm engine with stock j-spec turbos mine first dynoed at 386hp. A few weeks later with brand new stock j-spec turbos fitted (the original 1st turbo went pop on the dyno!) in TTC at 1.2bar with the addition of an HKS EVC, HKS Type R FMIC, in256/ex264 cams in CW rebuilt head, 680cc injectors mapped with an eManage it made 429hp. If you consider a stock j-spec Supra at 0.8bar when new made something around 320hp, those sort of numbers IMO look about right for the increase in boost and modifications. Quote Link to comment Share on other sites More sharing options...
Scott Posted October 24, 2015 Share Posted October 24, 2015 So you think the mods listed are worth 30hp more than your second setup Nic? Quote Link to comment Share on other sites More sharing options...
Benjy Posted October 24, 2015 Share Posted October 24, 2015 So by everyone's dyno graph bashing, Devil Developments dyno is wrong? Does that mean all of SRD's cars that have been run on that dyno have got less power than the graph suggests? All I see when Lee has one dyno'd on there is "Wow, good figures!" Nobody ever questions those figures from the SAME dyno, so why is Toms print out instantly brought into question? The "maximum of 380bhp at BPU" argument is about as accurate as "J-Spec turbo's will explode if you go above 1.2 bar..." Quote Link to comment Share on other sites More sharing options...
Scott Posted October 24, 2015 Share Posted October 24, 2015 So by everyone's dyno graph bashing, Devil Developments dyno is wrong? Does that mean all of SRD's cars that have been run on that dyno have got less power than the graph suggests? All I see when Lee has one dyno'd on there is "Wow, good figures!" Nobody ever questions those figures from the SAME dyno, so why is Toms print out instantly brought into question? The "maximum of 380bhp at BPU" argument is about as accurate as "J-Spec turbo's will explode if you go above 1.2 bar..." There are so many variables that I'm guessing most people would take dyno graph readings as pub talk. The most important thing is that the figure is decent and curve etc is good. It's like measuring a metre with your arms, everyone will measure it differently. Good example of that is the hub dyno's. They claim to give you hub HP but they're MUCH closer to FWHP than some people realise. Loads of people overestimate their power, noone underestimates it? For example, as I've said before, according to one dyno my car had just under 500hp. There's not a chance in hell that that's true. As for the 1.2bar thing, noone says they will explode but they certainly will degrade MUCH faster over that level at the top end. The one thing I really don't agree with is the 100% duty thing, unless I don't understand duty. At 5krpm the fuel consumption is much lower than at 7krpm yet the AFR stays the same. If they were at 100% duty at 5krpm the fueling would be much richer than at 7krpm. Just with the above, everyone has different opinions on what's going on. People don't like their chips being pissed on though,so that's just the way of the world. 400hp in the Sup is good for a 112mph et on the quarter mile..... good way of comparing power. Quote Link to comment Share on other sites More sharing options...
