2jz-gte vvti oil controle valve
TheRhdsupra
Hi mate, these are about £120 new from Toyota, do you mind me asking why you are needing one? Only reason I ask is I was going to take mine out and clean it up as a matter of routine maintenance and see if it helps with a low warm idle on my car, are you experiencing an idle issue or other problem as a result of the oil control valve? I read on a few other forums it can cause problems so just interested to hear about yours. :)
