Dazzi Posted October 21, 2015 Share Posted October 21, 2015 1996 White Facelift hybrid auto £4̶5̶0̶0̶ open to offers NOW £4300 Loocated Ripon, North Yorkshire We already have 2 Supra's at home so this is a reluctant sale but we need a more economical car for our family. I have owned the car for the last 2 and a half years and it has never missed a beat. I have done as much possible maintenance wise since owning it in 2013. This was NA-T'd in 2015 but recently returned back to stock. Imported in 2008 4 previous owners Around 177279km but will rise slightly (still reads in km) MOT 17 July 2016 (173935km) 2 advisory items - front shock absorber has a light misting of oil - replaced with new BC racing coilovers (174560km) and near side rear wheel bearing has 'slight' play. Since I have owned the vehicle I have done the following work: 2013 147,896km Differential (LSD) fluid change 151,843km Transmission filter and fluid flush, oil and filter change, power steering flush 2014 160,488km Battery, power steering flush, spark plugs, cam cover seals, distributor seal, oil filter housing seal, oil pressure switch, distributor cap and rotor arm, 2 x 02 sensors, silicone radiator hoses, rear pads and discs. 160,898km A343/0E hybrid auto box, transmission filter and 8.5 litres transmission fluid. 162,791km Brake fluid change 163,627km Walbro 255LPH fuel pump and fuel filter, new antenna mast. 169,404km Oil and filter change, spark plugs, air filter 2015 169,631km Waterpump, thermostat, coolant change, cam shaft oil seals, crankshaft oil seal, cambelt and tensioner, reconditioned alternator 170,773km UK front brake caliper upgrade, UK front pads, shim kit and 323mm front discs, Motoria catback exhaust 172,421km Handbrake cables and parking brake shoes 173,023km 235/40R18 front tyres, rear upper control arm poly bushes 173,501km Whifbitz tensioner pulley and auxiliary belt 174,560km BC racing coilovers, front stabilizer links 176,817km Front and rear anti roll bar poly bushes 177,279 Oil and filter change, cam cover seals, spark plugs Specs from my Supra garage: Engine Specifications: Stock 2JZ-GE Pre-Facelift Engine Mounts A/C Delete 6PK1863 Auxiliary Belt Whifbitz Tensioner Pulley Cooling: OEM Radiator OEM Viscous Fan Induction: 3" Green cotton air filter Fuel, Tuning & ECU: V-Power Nitro Walbro GSS342 255 LPH Fuel Pump Magnecor 8mm Spark Plug Leads NGK BKR5E Spark Plugs Charcoal Canister Delete Exhaust: Stock cats Motoria 3" Cat Back Drivetrain: A343/0E Hybrid Auto Box -600ftlb TT Flex Plate TT Torque Converter TT Propshaft TT Differential Flange A01B Torson Limited Slip Differential Suspension, Wheels, Tires & Brakes: BC Racing RS Coilovers Strongflex Rear Upper Wishbone Polyurethane Bushes Strongflex Front and Rear Anti Roll Bar Bushes 18" Team Dynamics Jade R 8.5" Front 9.5" Rear Wheels UK Front Brakes J-Spec Rear Brakes Braided Brake Hoses Interior & ICE: Auto to Manual Shifter Conversion Momo Millenium Sport Steering Wheel AEM Digital Transmission Temperature Gauge Beat 600 7" Double DIN Touch Screen DVD/CD Player JDL Door Speakers Pioneer Carrozzeria Rear Speakers Phoenix Gold Tantrum 200.2 Amplifier JBL CS1004T Subwoofer Tinted Front, Side and Rear Windows Exterior: OEM Body 6000K HID Head Lights LED Side Light Bulbs LED Reg Plate Light Bulbs Car looks to have been resprayed at some point. Bad bits ( they all have them ) Bonnet has a couple of stone chips NS sill below the door in front of side pod has a dent (can be seen in picture 4, more pictures to follow) OS quarter above side pod looks to have had body work at some point. OS rear spat/under spat area has a crease where paint has flacked off (picture to follow) Both rear spats have paint runs underneath Paint on front bump has flaked off in some areas Rear reg plate has worn the paint slightly at the bottom A few of the wheels have slight curb marks Immobilizer doesn't work Picture when car had side skirts - these have been removed. Supraman badge has also been replaced with a stock toyota badge. Transmission gauge included in glove box (far right). Other 2 gauges have been removed. Link to comment Share on other sites More sharing options...
s-u-p-r-a Posted October 26, 2015 Share Posted October 26, 2015 This is a very nice car, well looked after GLWS Link to comment Share on other sites More sharing options...
Parm_93 Posted October 27, 2015 Share Posted October 27, 2015 GLWS mate, hope you don't regret this! Link to comment Share on other sites More sharing options...
Dazzi Posted October 30, 2015 Author Share Posted October 30, 2015 Thanks guys. Couple of new pics Link to comment Share on other sites More sharing options...
Dazzi Posted October 30, 2015 Author Share Posted October 30, 2015 A few more Link to comment Share on other sites More sharing options...
Dazzi Posted November 2, 2015 Author Share Posted November 2, 2015 Update with pics of the sub and amp. Link to comment Share on other sites More sharing options...
Dazzi Posted November 3, 2015 Author Share Posted November 3, 2015 Dropped to £4250 Link to comment Share on other sites More sharing options...
