Koni shocks and eibach springs
Guest suprageek
Eibach pro kit lowers the car by 30 mm front and 25 mm rear if I remember correctly, I had them with new OE Toyota dampers, they have a good progressive spring rate that is just a bit more than stock
Eibach front --- 370 to 510 rear 180 to 263 lbs/in
Stock UK -------- 430 and the rear 219 lbs/in
Pardon my ignorance, but if someone had swapped out stock suspension for (tein) coilovers, would the top mounts have been removed or re-used? If they get removed, I still have the stock shocks and springs with potentially top mounts from my car if you want them Dave
