Would these rims fit?
krisgowing
Gonna be totally honest here I have no idea how rims fits ie the size and what you need to look out for.
My current 19inch alloys are chrome which has tarnished and look's well.. terrible.
I've been looking at another pair or alloys just while I save up for a brand new pair.
As my tyres are getting low I'll be getting some new ones ready for winter.
I've looked at these just for a little while as I used to have some similar on my old car https://www.gumtree.com/p/wheel-rims-tyres/4x-bmw-alloy-wheels-/1138557435
But what do I need to look at when looking at rims for the Supra.
Appreciate any help and I'm probably being very dimwitted but I'm a rookie when it comes to this!
The measurement where the holes are that the wheel nuts fit is called the PCD and on a mkiv is 5 x 114.3, this
has to be correct
The Spigot bore is 60.1 mm on a mkiv, this is the hole on the inside of the wheel which should fit on the spigot hub, it is best to be this size
but can be bigger and then you use spigot rings.
The BMW wheels have the wrong PCD so wont fit as they are 5 x 120
has to be correct
Stock 17" wheels are 17x 8 front and 17 x 9.5 rear and both have a 50 offset
http://www.willtheyfit.com is useful tool to check when changing wheels and you can compare to stock or whatever you have fitted now
