Please help
Max5437
Just picked up a gt4 and needed oil and my genius father put it in the charge cooler instead of the engine oil, put about 100ml in but now the engine light has come on. I'm stuck at a services about 100 miles from home. Any help greatly appreciated!!
If you have some way of bridging the E1 & TE1 on diagnostic ports, see what error codes it is giving you, as this may give you a better indication of whats going on.
edit: just realized this is on a GT4, no idea if their diagnostic system works the same as the supra
Do you recon it would be safe to drive home safely ? Babying it the whole journey and no boost at all ? Horrible first drive for my first turbo car hAha bit do you redo it would be okay? Read online that it should be in a limp mode too so should be safe? Thanks for your help guys, best forum by far :)
Ill have a chat with my local mechanic (member on here) as i have literally nothing to flush it with or any form of pump to do it properly and yes i know, its my fault for not doing it myself but as his age the expectancy for him to be able to read a cap that said engine oil should have been in his capabilities and to be honest I just wanted to get out the services and enjoy driving it home, nice and ironic that is, thanks Chris :) I don't suppose you happen to make your fast road pads for the gt4?
A full set of my fast road pads for the UK spec Supra are the same, the ST205 uses those pads too, so they are on special offer at £140 plus VAT a full car set with free insured P&P to a UK post code. So that's £168 in total, delivered, and I have them in stock. I recommend stock discs, they are excellent quality unlike many aftermarket ones originating from the east and made from recycled bicycles, form what
