Guest 500e Posted October 17, 2015 Share Posted October 17, 2015 I am looking for the full front and rear Lance Alignment specs. I came across a URL in a old post that links to the Tech Article for Lance Specs: http://mkiv.com/techarticles/lance_alignment/index.html but the url does not work. Can someone please send me a new link or list out the full specs? I am in the US so not sure if the units need to be different. Thanks Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 17, 2015 Share Posted October 17, 2015 Front: Camber - 1.0 degrees Caster + 5.0 degrees Toe 0.00 mm Rear: Camber -1.5 degrees Toe in (total) 1.00 mm (on 255/40R17 tires this rear toe equates to .090 deg, i.e. .045 deg per side) (on 275/40R17 tires this rear toe equates to .088 deg, i.e. .044 deg per side) http://www.supraforums.com.au/forum/topic/64610-wheel-alignment-settings-thread/ Link to comment Share on other sites More sharing options...
