Led rear lights.
Kendo11
Been very busy recently but I have made some decent progress.
I got some dark black self adhesive material that I've stuck on the central parts of the discs, so as to try to keep the LED rings highlighted.
I then got on with getting the wiring sorted correctly and then started to get the units put back together.
Basically just the reverse of dismantling them. When I know everything works I'll get all of the connections properly crimped together.
One unit just about put together.
A sneak peak of one 95% finished and connected.
More progress to come!
- - - Updated - - -
Sorry about the quality of them bloody pictures again also!
  • Replies 58
Posted Images
Kendo - I've been using these LED rings in mine for a year or so now, they do spit the odd led on a regular basis so make sure it's not to much drama to take the back out and replace. They will also be too bright for tail lights - ok for brake/indicator/fog but you'll need resistors on the tail lights, only a small drop tho try 50/100ohm. 1K dims them way too much
Btw looks really sweet man!! I just put the red rings in for tail lights and kept the rest bulbs, but yours look wicked!! Another thing I did was paint a thin coat of red onto them to blend inside the lense, but since you're using filter paper that may not work for you!
Excited to see the finished product!
  • 1 month later...
Some updates on this.
I got all the wires crimped together properly, then decided to wrap them as opposed to spray tinting them.
I first went with a really dark one but it ended up looking too dark and totally hiding the rings.
So today I wrapped them in a fly eye wrap which works much better.
Quick teaser shot of them on also.
Just need to reattach the rubber surround and then they're ready to fit.
How much would you say this has cost you? If you don't mind me asking.
I've been planning on doing an led conversion for ages but this seems much simpler and less fiddly.
Course not mate.
At the moment for absolutely everything I've used I'm sitting in between £40-£50 I think.
  • 2 months later...
Quick couple of pictures to show them finished.
Not fitted but you get the idea:
I do want to source some C-West covers at some point.
Further updates for these will be in my project thread as per my signature.
(padlock is to stop my unfitted bumper blowing away in the wind!)
  • 7 months later...
Final pic of these on this thread, fitted and working at night time.
I may have another go at these and adjust the layout - the light that is off is the brake light.
Might change it around next time, and still need to get them properly tinted. The 'bug eye' wrap looks good but the tinting will be more permanent.
Rainy and crap camera I'm afraid:
I also stumbled on these old Z lights that I think are incredible, so I might have a go at something like this next:
Further updates and pics of these will all be on my main thread (in sig) from now on.
  • 1 month later...
