ben_harmer32 Posted October 15, 2015 Share Posted October 15, 2015 Headlight bulb went. Bought a 2006 buld but it doesn't fit?? Any ideas please? Link to comment Share on other sites More sharing options...
ripped_fear Posted October 15, 2015 Share Posted October 15, 2015 (edited) What headlights do you have uk and Jspec are different. They actually say the bulb in the lence of the headlight itself http://www.mkivsupra.net/vbb/showthread.php?142251-Which-headlight-bulbs-for-JSpec-and-UK-Spec Edited October 15, 2015 by ripped_fear (see edit history) Link to comment Share on other sites More sharing options...
Dim Sum Posted October 15, 2015 Share Posted October 15, 2015 What headlights do you have uk and Jspec are different. They actually say the bulb in the lence of the headlight itself Yeah that, its at the bottom half on the corner of the lens Link to comment Share on other sites More sharing options...
Nic Posted October 15, 2015 Share Posted October 15, 2015 What headlights do you have uk and Jspec are different. They actually say the bulb in the lence of the headlight itself http://www.mkivsupra.net/vbb/showthread.php?142251-Which-headlight-bulbs-for-JSpec-and-UK-Spec These are the images that are not working on the linked thread above, can a Moderator edit the 1st post for future reference. Link to comment Share on other sites More sharing options...
Nic Posted October 15, 2015 Share Posted October 15, 2015 Headlight bulb went. Bought a 2006 buld but it doesn't fit?? Any ideas please? If you have j-spec headlights you need to use a 9005 bulb in the low beam, you will need to remove a rib on the inside of the wiring plug that connects to the bulb for it to fit. The tabs on the bulbs are slightly different, it is possible to fit them, but if you're having difficultly unscrew the ring on the back of the headlight, fit the bulb, then screw the ring back on. Link to comment Share on other sites More sharing options...
ben_harmer32 Posted October 15, 2015 Author Share Posted October 15, 2015 Cheers guys I'll take them back and get 2005 ones Link to comment Share on other sites More sharing options...
Nic Posted October 15, 2015 Share Posted October 15, 2015 Cheers guys I'll take them back and get 2005 ones 9005 Link to comment Share on other sites More sharing options...
