Guest Dazler Posted October 15, 2015 Share Posted October 15, 2015 Hi guys, does anyone know how to remove a headlight from a 1994 model? What method and technique is best? Cheers Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted October 15, 2015 Share Posted October 15, 2015 To remove the headlight from the car, there is 2* 10mm nuts and 1 10mm bolt that holds the headlight in. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted October 15, 2015 Share Posted October 15, 2015 Easy enough to do: Open the bonnet Un-clip all four lights - Main, Dipped, Fog & Side Undo the 10mm bolt on top towards in the middle of the car ( next to main beam ) Inside by the win are 2x10mm one on top of the other, undo these Wiggle the headlight out Quote Link to comment Share on other sites More sharing options...
Guest Dazler Posted October 15, 2015 Share Posted October 15, 2015 I just looked now and I see them bolts you mentioned, looks more straight forward than I thought :-) Many thanks Quote Link to comment Share on other sites More sharing options...
mattdavies Posted October 15, 2015 Share Posted October 15, 2015 I just looked now and I see them bolts you mentioned, looks more straight forward than I thought :-) Many thanks I had thought that maybe you hadn't looked at it, its a straight forward task Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted October 15, 2015 Share Posted October 15, 2015 Mate its really easy 3 minute job if that per headlight Quote Link to comment Share on other sites More sharing options...
berg Posted October 15, 2015 Share Posted October 15, 2015 Every supra ive seen only has the 1 nut on the wing aswell so even quicker lol Quote Link to comment Share on other sites More sharing options...
