G9RGE Posted October 15, 2015 Share Posted October 15, 2015 Im looking to fit a wideband to my 1jz converted supra. The original 02 sensor is in the downpipe off the back of the turbos which i will need to keep for the ecu. I was wondering if it would be ok to get the wideband welded into the front part of my 2nd decat pipe as the original downpipe is cast and will be a nightmare. Will this location be ok and give me the right readings? Thanks Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 15, 2015 Share Posted October 15, 2015 The second decat pipe will be fine for the WB sensor, however it needs to be horizontal or higher in the pipe to avoid water in the exhaust. Link to comment Share on other sites More sharing options...
G9RGE Posted October 15, 2015 Author Share Posted October 15, 2015 Thankyou Link to comment Share on other sites More sharing options...
