TT power steering res on NA; information
Noz
Installing a TT res, where would I find a listing for the fittings used please.
Any exploded diagrams around please? Can't put my hand to any.
16th October 15 Update - Problem solved. Fitting information and part numbers added, including diagram. Everyone loves diagrams.
Edited by Noz (see edit history)
Solved.
Also found an old thread after I googled the part number of the port needed..
http://www.mkivsupra.net/vbb/archive/index.php/t-266911.html
For reference, relocating power steering res parts needed;
TT suction port union 44337-24020
suction port union O-Ring 90301-11016
TT reservoir and some 16mm hose and 10mm hose
Also - http://www.clublexus.com/forums/sc-1st-gen-1992-2000/492459-2jzge-na-t-tt-ecu-mod-158.html
(Replacing SC400 res with TT res in below comments)
"The other small hose half way up the side of the reservoir is the return line back from the rack.
It's like a fountain the bottom hose of reservoir feeds fluid to the pump, pump pushes it through rack and back into side of reservoir to start over again.
The stock one is bolted to the power steering pump, and then there is a nipple for a small hose half way up the side.
The sc400 one instead of being bolted onto something has a nipple for a large hose coming out the bottom, and then there is a nipple for a small hose half way up the side.
So just take the small hose from the stock reservoir, and extend it to the side of the sc400 reservoir. its the same size so it should slide on the same and use a new clamp on it.
I don't actually extend it though if you follow the small hose it goes to a hardline right by the fusebox, so I usually just remove it and use 1 longer hose from hardline to wherever the sc400 reservoir is going.
The bottom hose nipple on the sc400 resevoir for the larger hose, that needs to run to where the old power steeering reservoir was bolted down, basically running into the pump. To connect a hose onto the pump you need the nipple off a tt supra and the O-ring that goes with it.
these are the part numbers.
44337-24020 Union
90301-11016 Ring, O (ID= 19.5mm, OD= 22.5mm - difficult to source exact Part No, contact different supplier perhaps hosing company)
this union with the oring will bolt onto the top of the power steering pump (using one of the old reservoir bolt holes) and it will let you connect a hose to the pump so you can run it to the bottom of the sc400 reservoir.
Read more: http://www.clublexus.com/forums/sc-1st-gen-1992-2000/492459-2jzge-na-t-tt-ecu-mod-158.html#ixzz3oiWQJe1N"
