DT125 Posted October 13, 2015 Share Posted October 13, 2015 I'm loosing water from the rad overflow when the car is cooling down after its turned off . I have a blitz 1.3 rad cap and an after fmic . I had this last time I fitted a after market fmic . Do I need to fit an overflow bottle . Quote Link to comment Share on other sites More sharing options...
Scooter Posted October 13, 2015 Share Posted October 13, 2015 I would, if you have some room between your battery and the washer fluid filler cap you can fit one of these, I have.... http://www.ebay.co.uk/itm/SUZUKI-VITARA-1-6-8V-PETROL-RADIATOR-OVERFLOW-HEADER-EXPANSION-TANK-BOTTLE-/391263558178?hash=item5b19201a22 Quote Link to comment Share on other sites More sharing options...
ronttuk Posted October 13, 2015 Share Posted October 13, 2015 i went to breakers yard got a honda civic expansion tank for £2 fitted nicely by the battery bolted to the wing Quote Link to comment Share on other sites More sharing options...
DT125 Posted October 13, 2015 Author Share Posted October 13, 2015 ok so i need a expansion tank bottle . Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 13, 2015 Share Posted October 13, 2015 (edited) The system needs an expansion tank to work properly Edited October 13, 2015 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 13, 2015 Share Posted October 13, 2015 I did exactly the same as Ron, looks oem too Quote Link to comment Share on other sites More sharing options...
DT125 Posted October 13, 2015 Author Share Posted October 13, 2015 ok cheers for the advice Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 13, 2015 Share Posted October 13, 2015 Also a 1.3bar cap is way too strong, a standard 0.9bar is fine Quote Link to comment Share on other sites More sharing options...
Nic Posted October 13, 2015 Share Posted October 13, 2015 Also a 1.3bar cap is way too strong, a standard 0.9bar is fine over pressurising the system is a common cause of the heater matrix letting go, which is a complete dash out job to replace. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 13, 2015 Share Posted October 13, 2015 ^^^ The stuff of nightmares! Quote Link to comment Share on other sites More sharing options...
Big Mark Posted October 14, 2015 Share Posted October 14, 2015 The system needs an expansion tank to work properly That looks very smart, what tank is it? Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 14, 2015 Share Posted October 14, 2015 That looks very smart, what tank is it? Honda Civic Quote Link to comment Share on other sites More sharing options...
mattdavies Posted October 14, 2015 Share Posted October 14, 2015 I thought 1.1 Bar was the Standard rad cap ? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 14, 2015 Share Posted October 14, 2015 0.9 is the standard rad cap, 1.1 is an 'upgrade' Which it isn't. Quote Link to comment Share on other sites More sharing options...
DT125 Posted October 14, 2015 Author Share Posted October 14, 2015 I'll use a fanta bottle Quote Link to comment Share on other sites More sharing options...
DT125 Posted October 14, 2015 Author Share Posted October 14, 2015 over pressurising the system is a common cause of the heater matrix letting go, which is a complete dash out job to replace. http://i329.photobucket.com/albums/l399/jezz1978/Heater%20matrix%20change/Image019.jpg so I should use a standard rad cap Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 14, 2015 Share Posted October 14, 2015 so I should use a standard rad cap Yep, you gain absolutely nothing using a higher pressure cap, except putting extra pressure on your cooling system Quote Link to comment Share on other sites More sharing options...
DT125 Posted October 14, 2015 Author Share Posted October 14, 2015 Yep, you gain absolutely nothing using a higher pressure cap, except putting extra pressure on your cooling system ok cheers . I will use the standard rad cap , before I blow up my heater matrix . cheers Quote Link to comment Share on other sites More sharing options...
