Supra Kong Posted October 13, 2015 Share Posted October 13, 2015 Hi, If I am running 295 30 18 can I run 245 40 18 on the front, or should I go 245 35 18 on the fronts? Any advise greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 13, 2015 Share Posted October 13, 2015 How much clearance do you have. A 245 40 18 is 24 mm in diameter bigger than a 245 35 18 The 40 profile is 10 mm bigger than stock and the 35 profile is 14 mm smaller than stock http://www.etyres.co.uk/how-to-change-your-tyre-size/ Quote Link to comment Share on other sites More sharing options...
Supra Kong Posted October 13, 2015 Author Share Posted October 13, 2015 I'll have to roll the rear arches, just fitted new shocks and currently is sitting way to low, so I'll have to raise the ride height! That's quite a difference in diameter... I'll check the link later! Quote Link to comment Share on other sites More sharing options...
Supra Kong Posted October 15, 2015 Author Share Posted October 15, 2015 How much clearance do you have. A 245 40 18 is 24 mm in diameter bigger than a 245 35 18 The 40 profile is 10 mm bigger than stock and the 35 profile is 14 mm smaller than stock http://www.etyres.co.uk/how-to-change-your-tyre-size/ Cheers DNK that's such a good link!!!! Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 15, 2015 Share Posted October 15, 2015 This one is also very useful http://www.willtheyfit.com Quote Link to comment Share on other sites More sharing options...
