Few Q's on Supra maintance
Jellybean
Hey
i am getting
  • Oil pump
  • Water pump
  • Thermostat
  • Tbelt
  • Crank pulley is done, new Vbelt
  • Vernier pulleys with cam seals
  • Tomei Poncams shimmed & DTI
  • Valve Stem seals -- may as well if cams are getting changed
  • OsGiken Clutch installed
  • Billet shifter bushes
  • Refurbish Starter Motor
Questions
  • Is one tube of the Toyota Black sealant enough for putting on a new oil pump?
  • Should I do the rear seal too if the gearbox is coming off?
  • Any other inexpensive seals to do if everything is getting stripped?
Edited by Jellybean (see edit history)
