HID Fog Lighst Loom Advice Please :)
a98pmalcolm
Hey all.
Ok I have a hid kit for my full and main beams. I also have a kit on my fog lights.
My HID kit on my fogs used to work. But moisture started to enter the head lights as I didn't use the cap that covers the fog light bulb access.
So I thought I'd better do a better job and do the while cut and solder feeding the wires through the OEM holes of the fog light cap (after drilling them to make them bigger).
I also soldered and heat shrink the connections from the OEM fog loom to the ballast.
But ever since then there not working. I can't understand why. I even bought some new bulbs and before cutting them I just plugged them in an still no luck.
So I can only assume the fog light plug that goes to the ballast isn't wired correctly where I have soldered it into. And missed something real obvious.
I checked via google search but can only find instruction on how to do it on facelift not pre facelift. But the principle is the same.
I have put some pics below to see if anyone can shed some light light to help me. I have facelift lights hence the extended side light length.
Thanks
Paul
The loom
The wires coming from headlight fog
Edited by a98pmalcolm (see edit history)
