sidewaysdan Posted October 4, 2015 Share Posted October 4, 2015 Would this wheel pattern be ok for the supra? 5 x 114.3 9.5j 30 offset Cheers Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted October 4, 2015 Share Posted October 4, 2015 You might struggle with that offset on the front. Possibly the maximum you could run on stock front arches. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted October 4, 2015 Author Share Posted October 4, 2015 Yeah was afraid of that. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted October 4, 2015 Share Posted October 4, 2015 Im sure Rich.2211 said he used to run 9.5J ET30 on stock arches and it was the absolute limit for the front. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted October 4, 2015 Author Share Posted October 4, 2015 Mine sits quite low at the front as well Quote Link to comment Share on other sites More sharing options...
Benjy Posted October 4, 2015 Share Posted October 4, 2015 9.5J with a 30 offset should just about clear stock arches. A customer of mine has 9.5J ET12's and only needed a slight roll. He is running a bit of stretch though. Should be a perfect fit on the rear though. I run a 9.5J ET35 with a 275 tyre with no drama. Thinking of spacing them out slightly too. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted October 4, 2015 Author Share Posted October 4, 2015 Ok cheers chaps , may go ahead and order them then Quote Link to comment Share on other sites More sharing options...
kitch79 Posted October 4, 2015 Share Posted October 4, 2015 It'll poke of 1/2 an inch more than this Quote Link to comment Share on other sites More sharing options...
Rywalls Posted October 6, 2015 Share Posted October 6, 2015 I've got rota gtr 9.5j et30 fitted on all four corners, bit of a gamble but they fitted, only about 2mm brake clearance on the front like but no rubbing or anything on full lock left and right with 255 tyres, got 265 tyres on the back and they're a perfect fit could even do with spacing out abit. The car is on stock shocks with tein s tech springs but rolling all the arches before fitting coilovers so it can go lower Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted November 2, 2015 Author Share Posted November 2, 2015 Sorry guys another one. The fronts are 225 40 18 8.5j et20 The rears are 255 35 18 10j et12 Cheers Quote Link to comment Share on other sites More sharing options...
