amuse ecu
Guest supradavy
A rare ECU for the Supra, basically the standard ECU is fitted with an extra ROM board and then mapped to give better performance; the rev limit may have been increased, the fuel cut level probably raised and the fueling/timing tweaked to give better response and higher hp/torque.
As already said if you contact Amuse with the serial number they may be able to give you detailed information about what changes have been made.
http://translate.google.co.uk/translate?hl=en&sl=ja&tl=en&u=http%3A%2F%2Fwww.webamuse.co.jp%2Fnew%2Fproducts%2Fcpu.html%23TOYOTA
  • 4 weeks later...
Guest supradavy
I contacted amuse but they don't work with serialnumbers. They can only tell me if i have the name of the first buyer of the car. So i probably will never know. :-(
