K Sport or D2 breaks
Supraleeturbo
Lee, I would save your money mate. I haven't been happy with my brakes for a long time (UK brakes) but I finally cracked it for Dragonball v2! :)
I use my brakes hard, high speed stops down to roundabout speeds in concession, and have nearly set on fire two sets of CW fast road pads, and would always get brake fade too quickly.
So before Dragonball I gave it one last shot before I ditched the UK's and went for a big brake kit, and had all the old brake fluid flushed out and replaced with Motul RBF600, and the pads changed for Porterfield R4 Race Pads. All I can say is WOW! The do exactly what I want when I want, and didn't once get brake fade on DB, and I was really pushing them hard.
Lee just try a setup the same as mine and tell me what you think ;)
Thanks mate I think I'm going for the 8pot ksport With either the porterfields or ebc yellow stuff as they come highly recommend
Go with the Performance Friction pads mate, nothing beats them. I just wish the did them in UK caliper size, but they stopped awhile ago :(
Edited by Burna (see edit history)
It helps when your brake fluid isn't full of air and looks like a drunks piss sample, And cheers for leaving that job to me haha
Tim
TB Developments
I've got Alcon brakes on my car. Having run a car with both J-Spec and then UK spec brakes I have to say the Alcon brakes certainly feel more positive and are less prone to fade on spirited driving.
The UK brakes were certainly very good. Especially with the CW fast road pads. But I do think the Alcon brakes are a step up from the UK setup.
Tim
TB Developments
Thanks mate, you love it lol
What make are the pads mate ?
The make is Performance Friction Lee, Chris Wilson's race pads use to be these, until they stopped producing them in the UK caliper size :( I know of a couple of members who do a lot of track days and The Ring, who have changed their calipers just so they can run Performance Friction pads, they are that good! I would love a set for my UK calipers :(
Below is the link for you Lee:
http://www.pfcbrakes.com/
But surely if you got more Pistons pushing the pad the better the friction so better stopping ?
Sorry, this is totally false. Multi piston calipers are designed to reduce taper wear of long pads, just the same friction is achievable with 2 pistons. 8 piston calipers are purely pub talk material. You need to be addressing the areas you find the current brakes deficient. I wrote this years ago, it may have some useful info for you. I don't have time to write a long post on where multi piston calipers are of benefit but google caliper pistons, piston size and pad taper wear.
Brake upgrades can set out to try to achieve several objectives.
The commonest are to increase resistance to fade and or increase
braking effort for a given pedal effort. IE, the pads are
pushed against the discs harder for a given pedal effort than
before the upgrade, or the brakes will stop the car from 100 MPH,
hard, for more times before fade sets in, than previously. The feel
from the pedal, that almost intangible quality, can also be addressed
and sometimes improved upon by brake size, or pad material changes, or
brake flexi hose upgrades to something less squashy than rubber.
It's easy to get carried away by the thought of brake upgrades.
The limitation in most cars as to how short a distance they can
stop in is tyre friction. Leaving aside pedal feedback, and fade,
it is almost certain that a Supra on stock Jap spec brakes will
stop in just as short a distance as one with an AP six pot kit on
it, a Brembo kit, Pauls KAD kit, or whatever. It may not feel to
the driver that it does, but usually such is the case if you just
nail the pedal as hard as you can. The fancy kits may *FEEL* to
stop the car faster, due to less pedal effort, and a better bite,
but in reality, if you hit the pedal as hard as you can with stock
Jap spec brakes, UK spec brakes, AP kit, KAD, whatever, the car
will stop in the same distance. Repeat this test 10 times and stock
Jap brakes may be on fire and long since faded, or the fluid boiled,
UK ones may be very hot and bothered, but the upgraded ones will
probably still be working within pad, disc and brake fluid temp
limits. Add in the intangible "feel" factor, and a desire to brake
as hard as possible, using as little skill as possible, but WITHOUT
relying on the ABS to take over, and for sure a well set up brake
upgrade may well allow more finesse.
Herein though lies the rub.
Upgrade only the fronts and the brake balance of the stock car may
well be compromised. Let's take stock brakes. You press smoothly on
the brake pedal with (say) 50 pounds force. The car stops fine. 70
pounds, the fronts are just beginning to lock (car makers ALWAYS aim
for the fronts to lock first, as rear wheel lock makes the car very
unstable and liable to swap ends). The rears are doing as much work
as the brake engineers deemed safe to prevent premature rear lock up.
The ABS cuts in, and maximum retardation has been reached. Now, take
a car with big front discs and calipers. Only 40 pounds pressure now
gives a smooth, lock free and powerful retardation. 50 pounds and the
new, more powerful, (for the same pedal pressure), fronts are locking.
The ABS cuts in. BUT, and this is the crux, those original rear
calipers and discs are still well below the caliper pressure where
they are able to achieve maximum retardation without fear of the
rears locking.
In other words the FRONT brakes are doing TOO MUCH work, albeit without
breaking into a sweat, and the rears are, to exaggerate a bit,
just along for the ride. The BEST scenario is to upgrade front AND
rear brakes, carefully ensuring the original balance of effort at any
given brake pedal pressure remains as designed, but that the more efficient
front AND rear brakes stay cooler for more hard stops, and that old
intangible "feel" from the brake pedal is improved, at lower rates of
driver effort on the pedal. The latter may or may not be good or
desirable, and can be engineered out by changing BOTH front and rear
caliper piston sizes, or pad areas. In a race car the balance would
be adjustable via 2 brake master cylinders, with a driver selectable
change in mechanical leverage effort between front and rear brake circuits,
one cylinder operating the front brake calipers, the other the rear. This
can also be achieved on road cars, but to do so is usually complex and
expensive, especially if ABS and brake circuit failure safeguards are to be
maintained. It is far easier to calculate the caliper and disc sizes, along with
pad area and compound to achieve this, as near as available off the
shelf equipment will allow.
Caveat. I said before makers engineer more effort on the front brakes to
encourage straight line stopping if the tyres are locked up . They err on
the excessive side, as, in the wet, the rear tyres can take a lot more
braking effort than in the dry, due to less weight transfer onto the front
tyres, as they will lock before as much weight is transferred when the grip
of the road surface is reduced. So adding yet more front brake effort worsens
this existing imbalance, especially in the wet. If it were not for the
ABS the front wheels would be locking up very early. On the Supra a
relatively sophisticated ABS allows some effort to be taken off JUST
the fronts, and an artificial and very inefficient balance is returned.
On cars with lesser (1 or 2 channel) ABS, or no ABS at all, a brake
upgrade on just one end of the car can be lethal.
I have fitted the 6-pot Jeep Bimbo brakes to a Supra, they really need 19" wheels to clear, but with a re profile do just go under 18's".
Not a job for the feint hearted.
Nice job. I was considering these a couple of months back but never went down that road, not yet anyway.
Those Brembo SRT conversions did catch my eye, but I wasn't sure how viable an option they'd be compared with the dedicated Supra specific setups (F50 for example) in terms of brake bias etc. Obviously the price is drastically different, but I wouldn't want to feel the need to buy twice if they weren't 'right'? :)
I have been very pleased with my D2 8 pots with Pagid SR19 pads. I have been considering upgrading my jspec rears to UK rears to try and re-address brake bias as per CW's previous post.
I would steer clear of any EBC pads. Can recommend Pagid and Porterfield pads.
