fruity_south Posted September 25, 2015 Share Posted September 25, 2015 Hi all, So stumbled across a problem whilst in the middle of rebuilding the supra for what i think is the 4th and final time, this time purely for drag racing. on stripping the interior i removed the little mechanism which winds the windows up and down not realizing that by doing so the windows would roll down and obviously not go back up as not under the tension of the cable. i dont need the windows to roll up and down and just need to get it into the up position and stay there! has anyone any ideas? i will be going lexan at some point but not at this time as getting the correct wheels is more of a priority over replacing the glass windows with lexan. Any suggestions would be much appreciated. Quote Link to comment Share on other sites More sharing options...
mellonman Posted September 25, 2015 Share Posted September 25, 2015 Im not sure how the supra mechanism works but , could you not drill a hole in the rails and put a bolt through to lock it in position ? Quote Link to comment Share on other sites More sharing options...
fruity_south Posted September 25, 2015 Author Share Posted September 25, 2015 the mechanism has two cables going into it. one which winds it down the other winds it up and both under tension. im not sure how close the window is to the rail and i think the bottom of the window is actually higher then the access area. will have another look though at that idea. i wondered if maybe i should wedge small amount of timber in there and drill that to the rail. Quote Link to comment Share on other sites More sharing options...
mellonman Posted September 25, 2015 Share Posted September 25, 2015 If its as you say it is then you have to realse one and wind the other to lets the cables move might be hard to tell which way was up and what way was down though, thats just going on other cars that i have worked on though Quote Link to comment Share on other sites More sharing options...
