RPM rise but not the speed.
MBA-Supra11
Clutch slipping, as the other guys said, get OEM Clutch if you car is stock , maybe also check out the price of the SPEC clutch; Whifbitz on here do them
Not too sure if the W58 runs a dual mass flywheel, Toyota dual mass fly wheel is extremely cheap compared to the same setup they have on more exotic marques like the Maserati
clutch is knackered,
.......................or you may have another problem called the Toyota supra NA. as radical as the car may look it suffers from something disastrous called a 3.0 non turbo engine, meaning when you press the accelerator a PROPER supra with two gizmo's called turbo chargers take you to warp speed however the NA has a guinea pig under the hood by the name of bob who sadly suffers from asthma so when you press the accelerator poor bob is choked resulting in noise but he simply doesn't have it in him to get to you flying :D
love you guys and NA owners :D
:D
:rlol:
