Extremely noisy doors
SupraP-Z
Red rubber grease or white lithium greas eon the strap/plastic road on the front bit of the door going into the wing. rub some of that and open/close the door a few times. All sorted
Mine's the same, will be doing it tonight. I can get a picture to show what I mean if needed
Pure silicon grease, great staying power, high melt coefficient, lubrication, will not stain clothing. I apply it to the rear tailgate rubber seal as they can start squeking with the weight of the tail gate on the rubber seal, it makes the rubber look like new. A small pot at a plumbing merchants is circa £8 but well worth it. Can also be used in the engine bay as it does not get upset with high temperature. Hope this helps.
