SupraP-Z Posted September 22, 2015 Share Posted September 22, 2015 Theres always been a slight squawking sound as i open the the doors in the supra, nothing too bad. Recently its been sounding like a dying pig, how the hell do i get rid of that awful noise?! Any recommendations on lube that actually works? Quote Link to comment Share on other sites More sharing options...
T14PPA Posted September 22, 2015 Share Posted September 22, 2015 Try oiling the check straps and make sure all the bolts and nuts are tight Quote Link to comment Share on other sites More sharing options...
Al Massey Posted September 22, 2015 Share Posted September 22, 2015 WD40 usually works for a bit. But as above, oil the check straps and the hinges Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 22, 2015 Share Posted September 22, 2015 "White grease" in a spray can Quote Link to comment Share on other sites More sharing options...
Jellybean Posted September 22, 2015 Share Posted September 22, 2015 Use White Lithium Grease , dont go near WD40 Quote Link to comment Share on other sites More sharing options...
cered Posted September 22, 2015 Share Posted September 22, 2015 Red rubber grease or white lithium greas eon the strap/plastic road on the front bit of the door going into the wing. rub some of that and open/close the door a few times. All sorted Mine's the same, will be doing it tonight. I can get a picture to show what I mean if needed Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted September 22, 2015 Share Posted September 22, 2015 grease the moving parts and job done, i used wd40 but it doesnt last long, it needs thick gooey grease Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted September 22, 2015 Share Posted September 22, 2015 Lube it up and go all the way Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted September 22, 2015 Share Posted September 22, 2015 Pure silicon grease, great staying power, high melt coefficient, lubrication, will not stain clothing. I apply it to the rear tailgate rubber seal as they can start squeking with the weight of the tail gate on the rubber seal, it makes the rubber look like new. A small pot at a plumbing merchants is circa £8 but well worth it. Can also be used in the engine bay as it does not get upset with high temperature. Hope this helps. Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted September 23, 2015 Author Share Posted September 23, 2015 Thanks Guys, ive already tried WD40, doesnt last long at all. White lithium grease, silicone grease and red rubber grease are the answers i was looking for. I thought red rubber grease was for brakes! haha. Thank you all! Quote Link to comment Share on other sites More sharing options...
cered Posted September 23, 2015 Share Posted September 23, 2015 Grease is grease, I use my red rubber to cook pancakes. Gives them a nice pink colour. White lithium is good but it tastes like Californian butter. Blech. Quote Link to comment Share on other sites More sharing options...
