Shane Posted September 21, 2015 Share Posted September 21, 2015 (edited) I know I must be mad, but am on the verge of undertaking a head gasket and timing belt change on a 2.9 crdi Sedona with the engine in the car. Anyone here with experience of working on these? Edited September 22, 2015 by Shane Android always knows best (see edit history) Quote Link to comment Share on other sites More sharing options...
Benjy Posted September 21, 2015 Share Posted September 21, 2015 I know I must be mad, but am on the verge of undertaking a head gasket and timing belt change on a 2.9 crdi Second with the engine in the car. Anyone here with experience of working on these? HAHA! Good luck! Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted September 21, 2015 Share Posted September 21, 2015 Says it all really Quote Link to comment Share on other sites More sharing options...
T14PPA Posted September 21, 2015 Share Posted September 21, 2015 They are shit to work on. The suffer from cracked heads so make sure to get it tested Quote Link to comment Share on other sites More sharing options...
Shane Posted September 22, 2015 Author Share Posted September 22, 2015 LOL, yeah thanks guys for the re-assuring words! Yes I guess I should get the head tested as the symptoms are very much like a cracked head. Been looking at second hand heads but who knows without testing if they would be any better. I know they are shite but I picked up one very local to me in really nice condition with full leather and all the frills for £175 and its just what I am looking for with the 7 seats to take and leave at my holiday house in Romania. They must have struggled to make it so bad on MPG, was looking at the reviews last night from back in the day and apparently you are lucky to get 30 mpg out of them. Quote Link to comment Share on other sites More sharing options...
Benjy Posted September 22, 2015 Share Posted September 22, 2015 You going to run this one on your home brew diesel? Quote Link to comment Share on other sites More sharing options...
Shane Posted September 22, 2015 Author Share Posted September 22, 2015 You going to run this one on your home brew diesel? No, its common rail Quote Link to comment Share on other sites More sharing options...
Shane Posted September 28, 2015 Author Share Posted September 28, 2015 What an absolute POS to work on! Who designs these things? Quote Link to comment Share on other sites More sharing options...
David P Posted September 28, 2015 Share Posted September 28, 2015 You might be lucky and get away with a skim? That cam belt and tensioner looks like it'll be fun. Quote Link to comment Share on other sites More sharing options...
Benjy Posted September 28, 2015 Share Posted September 28, 2015 What an absolute POS to work on! Who designs these things? I wouldn't have even entertained it unless I was being paid to do it! Lol Quote Link to comment Share on other sites More sharing options...
Shane Posted September 28, 2015 Author Share Posted September 28, 2015 You might be lucky and get away with a skim? That cam belt and tensioner looks like it'll be fun. You reckon, its right on the valve seats now and there are valve chambers cut in the pistons, its very tight. Read on the Kia forums that the general consensus is that there's not enough on the heads for a skim, and this one already looks like it has had one in its lifetime. Sadly whoever did it previously didn't torque the bolts properly, one in particular was loose compared to all the others. Yes Kia say its engine out to do the belt change, but it can be done at a struggle, that's all stripped now. Quote Link to comment Share on other sites More sharing options...
Benjy Posted September 28, 2015 Share Posted September 28, 2015 You reckon, its right on the valve seats now and there are valve chambers cut in the pistons, its very tight. Read on the Kia forums that the general consensus is that there's not enough on the heads for a skim, and this one already looks like it has had one in its lifetime. Sadly whoever did it previously didn't torque the bolts properly, one in particular was loose compared to all the others. Yes Kia say its engine out to do the belt change, but it can be done at a struggle, that's all stripped now. Have you put a straight edge across the head to see if it's flat? Quote Link to comment Share on other sites More sharing options...
David P Posted September 28, 2015 Share Posted September 28, 2015 You reckon, its right on the valve seats now and there are valve chambers cut in the pistons, its very tight. Read on the Kia forums that the general consensus is that there's not enough on the heads for a skim, and this one already looks like it has had one in its lifetime. Sadly whoever did it previously didn't torque the bolts properly, one in particular was loose compared to all the others. Yes Kia say its engine out to do the belt change, but it can be done at a struggle, that's all stripped now. Maybe you're not lucky then? Quote Link to comment Share on other sites More sharing options...
Shane Posted September 28, 2015 Author Share Posted September 28, 2015 Have you put a straight edge across the head to see if it's flat? Yes its exceptionally flat, cant get a .1mm gauge through at any point. Quote Link to comment Share on other sites More sharing options...
Benjy Posted September 28, 2015 Share Posted September 28, 2015 Pressure test and refit it then. Quote Link to comment Share on other sites More sharing options...
Shane Posted September 29, 2015 Author Share Posted September 29, 2015 Pressure test and refit it then. Decided to pressure test and have it skimmed. Spoke to the engine builder/machine shop where I dropped it off to this morning and they reckon a light skim will be fine once the valves are out, assuming the test doesn't show up any leaks. Just ordered a water pump for it too, reckon its pointless putting it back together without a new one for the sake of £20 extra. Quote Link to comment Share on other sites More sharing options...
