Supra diff
ben_harmer32
Unless I was subscribed to that thread, it would be a bar steward to find, after 31 posts, ben_harmer32 N/A or T.T? stands even less of a chance and then requires a program that I don't have to open it.
Here it is.
http://www.mkivsupra.net/vbb/showthread.php?225050-Supra-specific-gear-diff-ratio-and-tyre-size-calculator
This site gives transmission and differential specs, 4AT, 5MT & 6MT, N/A and/or T.T.
http://mkiv.supras.org.nz/specs.htm
I recently ran the numbers with this calculator
http://www.wallaceracing.com/drag-sim.htm
and surprisingly, for drag racing it is slower to use an auto diff (3.769 or 3.538) vs a manual diff (3.266 or 3.133). The calculator assumes you can slip the clutch to a higher mph for the manual diff ratios, so it may not match what would occur in a real world test.
I switched to the 3.538 diff a while back thinking it would give me quicker time on the 1/4 mile, so I'm hoping it actually does. :)
You definitely feel much better acceleration in each gear with the 3.769 diff, but there are other things that offset that advantage.
With the 3.769 diff, it required changing into 5th at the drags back when I had the stock rpm limit, so it was no quicker then the 3.266 diff was on the 1/4 mile due to the extra gear change. A higher rpm limit would probably fix that issue though.
Also as you change from 1st to 2nd (and all other gear changes), it is at a lower mph, so the same time (say 0.5 sec for the gear change) not accelerating is worse for elapsed time. This is because you are going at a lower mph when you change gears so you cover less distance during the gear change time.
