Factory toyota amp.and sub
mike33
Amp yes (I could be wrong on this point as I have never owned a Supra that hadn't already had the stock sound system removed), sub no.
Amp is under the passengers seat. Sub, if fitted is in the boot behind the rear seats. If your car has the sub you will see it protruding from the boot carpet against the back of the rear seats.
