'94 UK TT Auto - Black
michael
I'd sell a kidney for that Michael, what a stunning stunning example of the car.
Gaz.
Sadly I only had £8k, a Supra and a selection of removed but unwanted body parts available by the time it sold :(
The spec:
o 1998 Rev5 MR2 Turbo GT-S Based Donor Car
o Fully Blueprinted Race specification, hand built 3S-GTE
o Apexi PowerFC ECU
o Apexi PowerFC Electronic Boost Solenoid
o Apexi PowerFC Handheld Controller
o Apexi Power Intake Induction Kit
o HKS 87mm Forged Pistons
o HKS 264 Degree inlet camshaft
o HKS 264 Degree exhaust camshaft
o HKS Adjustible vernier cam pulleys
o HKS 1.2mm steel head gasket
o HKS Power timing belt
o HKS Super Fire Iridium Spark plugs
o HKS Triple Plate Clutch
o HKS Uprated Core Intercooler
o HKS Intercooler Pipe Kit
o HKS Super Sequential Blow Off Valve
o HKS Super Dragger Polished S/S Twin exit unit
o HKS Anti-cat bypass pipe
o HKS GT2530 Ball Bearing Turbo
o HKS Alloy Fuel Injection Rail
o HKS Top Feed 1000cc Injectors
o HKS Uprated 290L/ph Fuel Pump
o HKS Adjustible Fuel Pressure Regualtor
o HKS Electronic Boost Guage
o TRD Kit Body conversion
o TRD Engine mounts
o TRD Quickshift Kit
o TRD Gear Knob
o TRD Clear Side Repeaters
o Balanced, Lightweight Flywheel
o Polished Crank
o EL Sports Struts with Progressive Rated Springs
o Heavy duty ignition leads
o Trust Heavy Duty Oil Cooler with Relocated oil filter
o Trust High Flow Manifold
o Trust Exhaust Temperature Monitor
o Uprated Steel Braided Brake Lines
o Uprated Carbon Brake Pads
o Alpine Double Din CD/MD DSP/EQ Head Unit
o Recaro Racing Shell (driver)
o Recaro Sports Seat (passenger)
o Evolution Split Rim Alloys 17"x9.5, 17"x8.5
o Toyo T1-S Proxy's 255/40ZR17 Rear, 215/40ZR17 Front
30,000 miles on the clock and the only Cosmos Purple example in Europe, no more can come in under the current SVA laws.
Ah well someone bagged a beauty - I'm going out to play with the Supra in the rain now....
The spec:
o Apexi PowerFC ECU
o TRD Engine mounts
o TRD Gear Knob
o Polished Crank
It's got no neons though. Rubbish:stickpoke
  • 3 weeks later...
You do have some ups and downs with her.....
Yeah poor thing, the Supra isn't a problem it's me wanting to try other things constantly - I just wish I could afford to keep the black whale and then have £20k to spend on cars I can change every few months :)
Nice to see you are staying :)
I wouldn't have left here anyway, I have lifetime membership - I need to get value for money ;)
(change sig)
Good point!
Loads of coppers round my way lately! Not the sort of coppers you want though.
I've been looking at the money situation too. I'm drawing up a plan for all the mods I want to do and when I can afford to do them. First up, a new exhaust so I can put a stop to all the 'Is it an electric car. It makes no noise' comments.
