Parry_10 Posted September 19, 2015 Share Posted September 19, 2015 As above Fuel rail Injectors with harnesses Fuel pump Link to comment Share on other sites More sharing options...
Chris Bailey Posted September 20, 2015 Share Posted September 20, 2015 SRD fuel rail kit 1100cc ASNU injector kit Twin walbro 485 pumps Link to comment Share on other sites More sharing options...
Parry_10 Posted September 20, 2015 Author Share Posted September 20, 2015 SRD fuel rail kit 1100cc ASNU injector kit Twin walbro 485 pumps Only one 485 pump is needed Link to comment Share on other sites More sharing options...
Chris Bailey Posted September 21, 2015 Share Posted September 21, 2015 Only one 485 pump is needed I thought Jamie maxed his 485 pump out at around 600bhp ish on stock fuel lines? Link to comment Share on other sites More sharing options...
Guest Budz86 Posted September 21, 2015 Share Posted September 21, 2015 Think with ethanol J made around 680 but it needed a second pump to go more, but turbo didn't have much left so little point. Think lines had been done though otherwise I doubt he would have run it on eth On pump fuel mine makes 736 and 640 ft lbs and both pumps are running at that power Link to comment Share on other sites More sharing options...
Parry_10 Posted September 21, 2015 Author Share Posted September 21, 2015 I thought Jamie maxed his 485 pump out at around 600bhp ish on stock fuel lines? One 485 will do the job bud Link to comment Share on other sites More sharing options...
Luxluc Posted September 21, 2015 Share Posted September 21, 2015 Not of you run ethanol Chris Link to comment Share on other sites More sharing options...
Parry_10 Posted September 21, 2015 Author Share Posted September 21, 2015 Won't be running ethanol luc. But yeh you're right if I was I would need 2 pumps Link to comment Share on other sites More sharing options...
Parry_10 Posted September 21, 2015 Author Share Posted September 21, 2015 If you want an example Chris look at James (the turtleheads) car 708bhp on one 485 on pump fuel. It's when you use ethanol then it becomes a problem Link to comment Share on other sites More sharing options...
Luxluc Posted September 22, 2015 Share Posted September 22, 2015 You are right mate ; a single 485 should be good for 750 on pump fuel Link to comment Share on other sites More sharing options...
Parry_10 Posted October 6, 2015 Author Share Posted October 6, 2015 Still looking Link to comment Share on other sites More sharing options...
