Single build: whats not needed on the inlet manifold side?
T14PPA
Im trying to clean up my inlet side of the engine as im uprating my single turbo and injectors. Im just wondering what is not needed if you run a single set up. Im aware the charcoal canister and pressure tank is not needed. Is there anything else?
I don't think there is but I could be wrong, because you need every vacuum line to be pumped back for the stock inlet to work. You could polish/paint and clean in the inlet, but while you are taking it out I am pretty sure you see what needs tidying. If you ain't ready done it, fuel damper bypass is a must. Oh you can remove the fuel damper!
