ianhid Posted September 17, 2015 Share Posted September 17, 2015 Hi guys, I left a junction in a bit of a hurry last night and as I came off the gas heard a pop. Car proceeded to wheeze along at atmospheric for the 3 minutes to my door, won the traffic light GP though so that's good. On closer inspection it seems that a junction in the (stock?) pipes leaving the intercooler, roughly below the viscous fan has come apart. Are there any tips for keeping it together other than "do it up tight you muppet"? Thanks, Ian. Link to comment Share on other sites More sharing options...
scott.wild Posted September 17, 2015 Share Posted September 17, 2015 Hair spray seems to work Link to comment Share on other sites More sharing options...
fastcar Posted September 17, 2015 Share Posted September 17, 2015 Heavy duty jubilee clips would sort Link to comment Share on other sites More sharing options...
Benjy Posted September 17, 2015 Share Posted September 17, 2015 Hair spray and doing the clips up FT! Link to comment Share on other sites More sharing options...
j_jza80 Posted September 17, 2015 Share Posted September 17, 2015 Hairspray is a really bad idea. Pushing the silicone hose back on must be a bitch! Get some decent hoses and some proper constant tension clamps Link to comment Share on other sites More sharing options...
Benjy Posted September 17, 2015 Share Posted September 17, 2015 Hairspray is a really bad idea. Pushing the silicone hose back on must be a bitch! Get some decent hoses and some proper constant tension clamps Why? Link to comment Share on other sites More sharing options...
j_jza80 Posted September 17, 2015 Share Posted September 17, 2015 As said, getting the silicone hoses on/off when hairsprays there must be a nightmare. Just buy the correct size hoses and some Murray clamps, and they will never blow off. - - - Updated - - - As said, getting the silicone hoses on/off when hairsprays there must be a nightmare. Just buy the correct size hoses and some Murray clamps, and they will never blow off. Link to comment Share on other sites More sharing options...
Benjy Posted September 17, 2015 Share Posted September 17, 2015 That's the point, you don't want them to pop off, which is why hair spray's a good idea. Pretty sure the IC pipework's stock on Ian's car, so Toyota clamps should suffice. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 17, 2015 Share Posted September 17, 2015 Hair spray works fine, it's not Araldite and you can still get the hoses free again. It just dries to give them more ppurchase. be sure to clean all oil and grease from inside the hoses and outside of whatever they push over with something like brake cleaner first. Link to comment Share on other sites More sharing options...
j_jza80 Posted September 17, 2015 Share Posted September 17, 2015 Still don't see the need for bodges swaged pipes, correctly sized joiners and high quality constant tension clamps will do the job. Link to comment Share on other sites More sharing options...
Benjy Posted September 18, 2015 Share Posted September 18, 2015 Mr Wilson, you bloody bodger you! Link to comment Share on other sites More sharing options...
mattdavies Posted September 18, 2015 Share Posted September 18, 2015 Hairspray is to Hoses what Loctite is to bolts !! It certainly isn't a bodge, its just a trick of the trade more then anything else Link to comment Share on other sites More sharing options...
bignum Posted September 18, 2015 Share Posted September 18, 2015 (edited) We used to fix our bmx bike grips on hairspray lol works wonders , thinking something about Mary now don`t know why, Edited September 18, 2015 by bignum (see edit history) Link to comment Share on other sites More sharing options...
clay Posted September 18, 2015 Share Posted September 18, 2015 GOD has spoken use hairspray I meen Chris ( not benji ) Link to comment Share on other sites More sharing options...
j_jza80 Posted September 18, 2015 Share Posted September 18, 2015 Hairspray is to Hoses what Loctite is to bolts !! It certainly isn't a bodge, its just a trick of the trade more then anything else Loctite is meant for bolts! Link to comment Share on other sites More sharing options...
ianhid Posted September 18, 2015 Author Share Posted September 18, 2015 Sounds like I'm off to Superdrug at lunchtime then. Anyone want anything while I'm there Link to comment Share on other sites More sharing options...
Benjy Posted September 18, 2015 Share Posted September 18, 2015 We used to fix our bmx bike grips on hairspray lol works wonders , thinking something about Mary now don`t know why, http://i633.photobucket.com/albums/uu56/bignum/images_zpsb31jo1rz.jpg Did you also use harry munk as glue? Is that why you're now thinking about Mary? Link to comment Share on other sites More sharing options...
Pete Posted September 18, 2015 Share Posted September 18, 2015 Lower the boost? Link to comment Share on other sites More sharing options...
bignum Posted September 18, 2015 Share Posted September 18, 2015 Did you also use harry munk as glue? Is that why you're now thinking about Mary? Haze air freshner mate lol Link to comment Share on other sites More sharing options...
Golfpro Posted September 18, 2015 Share Posted September 18, 2015 Are the pipe ends beaded or plain? Mine kept popping off even with two heavy duty straps on each end Bought a hand made pipe beader off ebay for £30. Now one clip on each pipe, problem sorted Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 18, 2015 Share Posted September 18, 2015 I was assuming stock pipework. Link to comment Share on other sites More sharing options...
ianhid Posted September 18, 2015 Author Share Posted September 18, 2015 Yeah, the pipes are stock. It's running up to 1.2 on J-spec's, as long as I remember to lift at about 5k. Got another leak/issue in there somewhere that's kicking it up towards , highest on recent record was 1.5, that's a bit too high for my wallet at the moment. Currently hunting for problems but may have to give it to someone with skills to track down. Link to comment Share on other sites More sharing options...
Supraleeturbo Posted September 19, 2015 Share Posted September 19, 2015 (edited) Sorry just notice you have stock pipe work. This is how mine is done and not had one pop off yet fingers crossed Edited September 19, 2015 by Supraleeturbo (see edit history) Link to comment Share on other sites More sharing options...
j_jza80 Posted September 19, 2015 Share Posted September 19, 2015 Now you're just showing off Link to comment Share on other sites More sharing options...
