evinX Posted September 17, 2015 Share Posted September 17, 2015 Had this problem years ago on my hardtop, now my aero developed it. What the cause again people? cheers, Kev Quote Link to comment Share on other sites More sharing options...
mharvey Posted September 18, 2015 Share Posted September 18, 2015 I've got this in my hard top. SOAKING wet lately so I'm also interested. Can't tell where about's it's coming from Quote Link to comment Share on other sites More sharing options...
gordy.r Posted September 18, 2015 Share Posted September 18, 2015 Yep I suffer from this with my hard top as well, interested to see what replies and solutions are given. Quote Link to comment Share on other sites More sharing options...
Supraleeturbo Posted September 18, 2015 Share Posted September 18, 2015 I know the answer to this but will cost you 5 dollar for the answer heheh. So basically where the glass meets the rubber on your door that's between the rear quarter window that's where it leaks! now you want to know how I stopped it?? I just cleaned it with a bit of apc then dried it and no more wet seat belt, job is a gooden :-) hope this helps lads Quote Link to comment Share on other sites More sharing options...
evinX Posted September 18, 2015 Author Share Posted September 18, 2015 I noticed as I got in, my rubber near the qtr glass was out instead of in, pushed in and waits to see. Will update with pics if it works Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted September 18, 2015 Share Posted September 18, 2015 (edited) Hi supraleeturbo, What size and make are your rear tyres, also do you have spacers fitted? Your car looks great from the back, really beefy. many thanks. Edited September 18, 2015 by herbiemercman added extra text. (see edit history) Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted September 18, 2015 Share Posted September 18, 2015 Had this problem years ago on my hardtop, now my aero developed it. What the cause again people? cheers, Kev Hi evinX, I had this problem couple of years ago, first i sealed the rear side window, just between the glass and the rubber with silicone, i also cleaned out the drain hole in the centre of the roof gutter, finally i cleaned out the drain hole at the top of the door rubber which the water runs inside the rubber seal. Can't say which of these cured the problem but who cares they all needed doing. Hope this helps. Quote Link to comment Share on other sites More sharing options...
evinX Posted September 18, 2015 Author Share Posted September 18, 2015 Ok ill check these out to, thanks herbie Quote Link to comment Share on other sites More sharing options...
Scott Posted September 18, 2015 Share Posted September 18, 2015 New window seal is the best solution but there's that silicone additive rubber spray stuff that apparently does a good job to rejuvenate the seal Quote Link to comment Share on other sites More sharing options...
Supraleeturbo Posted September 19, 2015 Share Posted September 19, 2015 Hi supraleeturbo, What size and make are your rear tyres, also do you have spacers fitted? Your car looks great from the back, really beefy. many thanks. My wheels are advan rs wheels 10j rear 9j front with a mitchelin pilot sport 245/40/18 front and a 295/35/18 rear and no, no spacers just the rears have been cut out but you car just roll them. Hope this helps buddy Quote Link to comment Share on other sites More sharing options...
Ric Posted September 19, 2015 Share Posted September 19, 2015 Have a look at my FAQ thread - http://www.mkivsupra.net/vbb/showthread.php?314767-The-Mega-Aerotop-Leak-Fix-Thread-FAQ More than likely a disconnected rear drain. Quote Link to comment Share on other sites More sharing options...
