Missing rear number plate
krisgowing
Morning.
After driving to Milton Keynes and back from Norwich yesterday I parked back at home and notice my rear number plate was missing.
Seems it must of came of at some point, Surprised I didn't get pulled at all.
Having the rear jap bumper I need the jap style number plate.
Everywhere I've tries so far just have the normal style.
Is it worth just doing this until I can find someone to do the bigger style or am I risking a lot by driving without one or making a temporary one, I'm not even sure I should debate that.
Is it easy to find a garage to do this style or would a Wilko etc have this.
No you don't.
A UK motorbike number plate covers the hole and then you can either tape it around the edges which I did for 16 years without loss though the tape did need replacing every couple of years when it started to lift. the final solution that I got around to after 16 years was to tape around the edges and screw to the bracket behind with, I think the size was M6, stainless screws. Now that plate isn't going anywhere.
I went to my local spares\parts garage and they had the Jap size. It was a motor spares shop which did number plates as well, worth phoning anyone local to you.
Though as others have mentioned on the web it is pretty good, I ordered some recently and they turned up in 2 days.
Also it should be fitted with the two screws, no way would that come off.
  • 4 weeks later...
